"Switching Transistor" OFF Impedance
8 replies · 2K views · last reply
sandy.bridge
Hey all,
When a Bipolar Junction Transistor is "OFF" (i.e., Vb = 0), what are typical Emitter-Collector impedances? We are using a switching BJT as a switch for a stepper motor, however, we have just realized that the impedance is rather low when the transistor is off (470 Ohms). I would have expected this to be much larger for a transistor that is built for switching.
The datasheet should list some of this - however how are you switching it "off" - do you have a pull down resistor?
We are sending it a signal from a microcontroller. Attached you will see a portion of the circuit. The problem is that when the bases are "low", or even floating, the circuit is drawing current.
  • Schematic of a 12V NPN transistor switch driving an NMOS gate: R2 from 12V to the NMOS gate node, Q1 NPN collector there, emitter to ground, R1 from the gate signal input to the base, and the NMOS M1 drain to MOTOR, source to ground.
I would use a 1K (?) resistor between the Base of Q1 and Ground. When the uC is Low, it is probably more like "floating" and the Q1 becomes a Voltage divider - allowing some leakage current - This also seems to be reverse logic ( when the uC is Low(Q1 off) the Motor is ON because the Gate of M1 gets Pulled up ) - is this what you want?
Wouldn't a positive signal at the input of Q1 cause a current to flow into the base and thus bias Q1 "ON"? This is merely a common-emitter amplifier, no?
  • Circuit schematic of an NPN transistor in common-emitter configuration with base resistor RS and base supply VBB, collector load RL and supply VCC, labelled currents IB, IC, IE and voltages VBE, VCB, VCE.
yes and that turns M1 ( the FET) off
As windact said its kinda reverse logic
In a switching circuit - think of ideals -- perfect switch.. If Q1 is "on" - ideally - what is the V at M1s Gate ... and conversely - if Q1 is "off" -- ideally -- what is the V at G-M1?
Your number 2 diagram --- is not the same as your #1 diagram...redraw #2 - in the arrangement of #1 and then add the parts that are missing.
As a matter of design best practices - the MOSFET is VERY FAST - what happens if the motor is running ( current flowing) any you "try" to turn it OFF VERY FAST??
Which particular NMOS transistor are you using?
You believe it has always behaved like this, or are you investigating now only because something has recently stopped working properly?
Or is this a new circuit that isn't yet working how you want it to? Certainly, an OFF transistor should present more than a few kΩ to low voltage DC.
