Sylow p-subgroups: Group of order 693
  • Thread starter Thread starter lola1990
    Group
The discussion revolves around the properties of Sylow p-subgroups in a group of order 693, specifically focusing on the structure and automorphisms of certain subgroups. Participants are examining the implications of subgroup orders and automorphism actions within the context of group theory.
  • Participants discuss the kernel of an action related to automorphisms and explore its implications for subgroup orders. There is an examination of the relationship between subgroups and centralizers, as well as the conditions under which certain orders can be ruled out. Questions arise regarding the nature of automorphisms and the structure of specific groups, including the automorphism groups of cyclic groups.
The discussion is active, with participants exploring various interpretations of subgroup properties and automorphisms. Some guidance has been provided regarding the nature of linear maps and their relationship to automorphisms, but there is no explicit consensus on the conclusions drawn from the discussions.
Participants are working under the constraints of group theory, specifically focusing on the orders of groups and their automorphisms. There are references to theorems and properties that may not be fully established or agreed upon, leading to ongoing exploration of the implications of subgroup orders and automorphism actions.
lola1990
I am having problems with parts c and d
For (c). You have an action that sends
\phi:C\rightarrow Aut(A)
with \phi(c):A\rightarrow A:a\rightarrow cac^{-1}.
What is the kernel of this action?? Use that C/\ker(\phi) is a subgroup of Aut(A).
For (d). You know that A is a subset of C(a) (show this). You know that B is a subset of C(a). And you know that C(a) contains an element of order 7 (what does this imply for the order of C(a)?)
ok, so for (c) I know that the kernel has order either 1 or 11, since it is a subgroup of C. If it has order 11, we are done because then every automorphism is the identity. I'd like to show that have order 1 leads to contradiction. If it has order 1, then |C/kernel|=11. But since the number of permutations of A is 9!, and 11 does not divide 9!, this leads to contradiction. Thus, the order of the kernel is 11 and every automorphism is the identity and fixes every element of A. Is this right?
For (d), if A is a subgroup of C(a) and B is a subgroup of C(a), AB is a subgroup of C(a) and |AB|=99 since |A intersect B|=1. Thus, |C(a)|>=99 or 231 or 693. I know that 99 can't be it, since as you said C(a) contains an element of order 7. But, why can't it be 231?
Also, A is a subgroup of C(a) because it has order p^2 for a prime p, and I have a theorem that says it is abelian as a result, so that conjugation is trivial.
Because A is a subgroup of C(a). So |A| must divide |C(a)|.
Oh wait, I messed up the first part. The two possibilities for the kernel are 1 and 7, and if it is 1 then |C/kernel|=7. Since the number of permutations of P is 9!, I'm unclear on why this leads to contradiction. Is there way to know |Aut(P)|<9! ?
A is either \mathbb{Z}_9 or \mathbb{Z}_3\times \mathbb{Z}_3. Can you calculate the automorphism groups of these two??
Oh, I do have a theorem that the automorphism group of the cyclic group of order n is isomorphic to (Z/nZ)^x. So, since the co-prime elements of Z/9Z are 1,2,4,5,7,8 the automorphism group of Z9 has order 6. Likewise, the automorphism group pf Z3 has order 3. Does this mean that the automorphism group of Z3 x Z3 has order 9?
That is correct.
Sadly, no. Here is the trick to finding the order automorphism group of \mathbb{Z}_3\times \mathbb{Z}_3.
  • Show that each automorphism is also \mathbb{Z}_3-linear. So our automorphism group is actually GL_2(\mathbb{Z}_3).
  • An element in GL_2(\mathbb{Z}_3) is determined by choosing a basis. How many possibilities are there to choose a basis of \mathbb{Z}_3\times \mathbb{Z}_3?
Just want to check that 0 is not an element of Z/9Z, right? Because then the order would be 7 and the proof would go out the window.
What do you mean by Z3 linear? I guess if f is an automorphism, then f(x+y)=f(x)f(y). Not quite sure if this is what you mean...
Well, \mathbb{Z}_3\times \mathbb{Z}_3 is a \mathbb{Z}_3-vector space. So we can define a linear map as something that satisfies
f(\lambda x+\mu y)=\lambda f(x)+\mu f(y)
Ok, so suppose f:P -> P is an automorphism. I guess I'm confused about how to go about showing that something is linear in Z3 if the function is defined on P, which has order 9.
I guess if P=Z3 x Z3, then we'd have to define f((x,y))=(g(x), h(y)). Then, f is Z3 linear iff g and h are Z3 linear. Is this right?
Also, I am talking about group isomorphisms, so I'm not sure how to deal with the constants.
You must show for \lambda,x,y\in \mathbb{Z}_3 that
f(\lambda(x,y))=\lambda f(x,y)
Ok, so just to recap, we want to find the number of automorphisms from Z3 x Z3 to Z3 x Z3. We want to show that f(x,y) is such an automorphism iff it is a linear transformation of Z3 x Z3 (represented by a 3x3 invertible matrix with entries from Z3). Ok, so if f(x,y) is an automorphism, and a,x,y are in Z3, then we need to show that af(x,y)=f(ax, ay). I am confused how to do this, because I only have theorems about addition.
Oh, sorry a 2x2 invertible matrix
Well, maybe your multiplication can be written as addition??
ooh... so ax=x+x+..+x (a times), s0 f(x,y)+f(x,y)...+f(x,y) (a times)=f((x,y)+..+(x,y) (a times))=f(a(x,y)). Is that right? So then, af(x,y)+bf(z,w)=f(a(x,y))+f(b(z,w))=f(a(x,y)+b(z,w)). Thus, if f is an automorphism, it is a linear map in Z3xZ3. Do I also need to show that a linear map in Z3x Z3 is an automorphism of Z3xZ3?
A bijective linear map will be an automorphism. You can show that if you like, but isn't that trivial??
Also, I'm not sure how to find the number of bases of Z3 x Z3. It would have to consist of 2 linearly independent elements of Z3 x Z3.
No, I do see why a bijective linear map is an automorphism. I know that the automorphism induces a linear map from Z3 x Z3 to Z3 x Z3, but do I know that it is bijective? Also, does a 2x2 matrix define a bijective linear map or just a linear map?
An automorphism is bijective by definition...
oh ok, got it. So then we have that a bijective linear map from Z3xZ3 to Z3xZ3 is defined by choosing a basis of Z3xZ3. I'm confused about this point- why is that true?
Also, I'm not sure how to find out how many bases of Z3x Z3 there are. Clearly, there are 9 possibilities for choosing the first vector (x,y). How can we then choose the second vector?
You can't choose (0,0). So there aren't 9 possibilities for the first vector.
Right, so there are 8 possibilities for the first vector (x,y). We know that the second vector (a,b) can't be a multiple of the first or 0. I am stuck on how to find out how many possibilities there are for the second vector.
Wait, so (a,b) isn't (0,0), it isn't (x,y), and it isn't (2x,2y). I think all others are fine, so that there are 6 possibilites for (a,b). So there are 48 bases, and |Aut(P)|=48. But, 7 doesn't divide 48, so that is a contradiction. Is that right?
why does the problem statement and most everything in the first post not show up?
