Does Synthetic Oil Offer Better Engine Protection Due to Its Lighter Weight?
  • Thread starter Thread starter bobbobwhite
    Oil Properties
Synthetic oil is widely recognized for providing superior protection to internal combustion engines compared to petroleum-based oils. The discussion raises the question of whether the lighter weight of synthetic oil contributes to reduced engine wear by allowing it to adhere better to moving components after the engine cools. However, the consensus suggests that the advantages of synthetic oils stem primarily from their stability at high temperatures and resistance to breakdown, rather than their density. Key factors influencing lubrication include viscosity, thermal stability, and heat transfer characteristics, rather than the oil's weight. Overall, while synthetic oils offer enhanced performance, their benefits are attributed to their chemical properties rather than their lighter density.
bobbobwhite
We have read that synthetic oil protects and preserves internal combustion engines much better than does natural petroleum. I have proven that to myself over many years in my own vehicles. A question first came to mind the last time I bought synthetic oil...I noticed that it is so much lighter in weight per volume than petroleum that it begs a question ...is at least part of the reason little to no wear occurs in an engine using synthetic oil due to more of the synthetic material remaining on the moving components after operation ceases and the engine cools, at least partially due to the lower gravitational pull on the lighter sythetic oil allowing it to remain on moving components better than heavier petroleum? If so, it would logically provide superior cold start-up lubrication, the lack of which is the cause of most engine wear.
Thus, is the superior protection of synthetic purely due to its superior lubrication qualities, or does it possibly involve other factors such as the above?
Thanks for informed responses.
Hmm, I don't know how informed my response is but here goes. I always thought the biggest advantages of synthetic oils were superior stability at high temperatures, and resistance to breakdown, oxidation and other chemical changes with long exposure to heat, exhaust blowby, etc. Most wear to bearings such as connecting rods occurs at high loads and stress (towing a boat or hard accelerations) rather than idling. My favorite auto lube website explains all this in great detail, although I don't think he addresses the differences between mineral and synthetic oils.
http://http://www.bobistheoilguy.com/"
Almost certainly not. The density itself doesn't play much of an effect with regard to lubrication. Properties such as viscocity, thermal stability, heat transfer characteristics, ash content etc all have much more of an effect. Obviously some of these will have an effect on density, but the density itself is not a critical property of a lubricating oil.
