GDogg said:
I don't think that's a violation of causality because there's no causal loop. Yes, I will know about my own future, but I'd be unable to alter it.
I think physicists usually define causality violations in terms of events in the future being able to "cause" events in the past, not in terms of "changing" the past. For example, I think physicists would agree that if closed timelike curves are possible using wormholes, then this is a violation of causality, even if something like the
Novikov self-consistency principle holds and it's impossible for a time traveler to actually change anything in the past.
GDogg said:
If I tried to send an FTL signal back to you (so it arrives before the atom decays and you can prevent it from happening) the obstacle would block it and you'd never find out.
Wait, didn't you just agree people could learn about events within their own future light cone? There should be no reason you can't send a signal back to me which travels FTL in your frame and which arrives before it was sent in my frame, unless the laws of physics don't work exactly the same in every frame. There's no reason the obstacle couldn't have a tachyon detector on the front, for example (its only purpose is to block tachyons which in my frame are being emitted by my source), and in any case you don't have to send your reply back on precisely the same path (you could send your reply to a location 1 mile to the left of me, and there'd be plenty of time for an observer at that location to relay the message via an ordinary radio signal before my radioactive atom decays).
GDogg said:
But now suppose there is no obstacle, and you emit a signal A when you see the radioactive decay in your region. Then I get your signal A and try to prevent the decay by sending you another FTL signal B which you will get before the decay. The end result: you will be the actual emitter of the signal B I tried to get you to absorb and this signal B will trigger the original signal A you sent when the decay happened.
Why would the signal B "trigger" the original signal A? And note that even if we choose an interpretation in which I "sent" signal B, the tachyons were still spontaneously emitted from my detector B in such a way as to give me a message from you about when the atom would decay. If something like the Novikov self-consistency principle held, I couldn't choose not to send that later signal A when it actually did decay, but my sending the signal wasn't really "triggered" by the signal B, it was triggered by seeing the decay.
GDogg said:
So even if you manage to prevent the decay, I'll still get signal A and I won't be sure if the decay actually occurs or not.
Why would I send the signal A if not because of the decay? I suppose I could be lying, but that would be true in a case involving conventional radio signals as well. I don't really understand your logic here...
GDogg said:
This is a variation of Ehler's Paradox, which is solved http://wildcard.ph.utexas.edu/~sudarshan/pub/1970_008.pdf" (page 144).
Their attempt to resolve Ehler's paradox also is just based on definitions of which event is a tachyon emission and which is a tachyon detection, but it does not address the point that a spontaneous tachyon "emission" from a detector can convey a message about the future to the person next to it. This must be true if tachyon signals can
ever convey information, since for any case where an observer receives a tachyon signal and gains some new information in brain mind from it, there must be some frame in which the tachyon signal was actually emitted by her detector, but different frames can't disagree on localized physical facts like what the observer experienced in her brain, the different frames would just be differing on their "interpretation" of whether the tachyons were being emitted or received by the same detector.
