Calculating Bending Stress & Moment of Inertia for Tapered Cantilever Beam
This discussion focuses on calculating the bending stress and moment of inertia for a tapered cantilever beam. The moment of inertia, I, is expressed as a function of the length coordinate, I(x) = (b(x)h(x)³)/12, where h(x) is defined by the equation H(x) = [(a-b)/L](x) + a. To determine bending stress, the section modulus at specific points is used with the formula σ = M / SM. The conversation also addresses deriving deflection equations for tapered beams, emphasizing the need for numerical integration when I is not constant.
  • Understanding of cantilever beam mechanics
  • Familiarity with moment of inertia calculations
  • Knowledge of bending stress and section modulus
  • Basic principles of numerical integration
  • Study the derivation of deflection equations for tapered beams
  • Learn about numerical integration techniques for beam analysis
  • Explore Young's Modulus and its application in bending stress calculations
  • Investigate software tools for structural analysis, such as MATLAB or Excel for beam calculations
Engineers, structural analysts, and students involved in mechanical or civil engineering who are working on the analysis of tapered cantilever beams and require a deeper understanding of bending stress and moment of inertia calculations.
d.saldana
Hello all,
I need to calculate the bending stress of a tapered cantilever beam. However, I would like to know how to calculate the moment of inertia.
For a uniform shape beam, I know the Ix=(bh3)/12, but since h changes throughout the length of the beam how would inertia, I, be calculated?
I was able to figure out the height of the beam as a function of x, H(x).
Equation for H(x)= [(a-b)/L](x)+a
where;
a= height of beam at fix wall
b= height of beam at end
L= total length of beam
x= point along length of beam.
Any help would be greatly appreciated!
d.saldana said:
Hello all,
I is still calculated in the usual manner, but instead of being a constant w.r.t. the length of the beam, I is now a function of the length coordinate.
I(x) = \frac{b(x)h(x)^{3}}{12}
and I(x) will still be about the centroid of the section.
To calculate bending stress, you can calculate the section modulus of the beam at the point or points where you want to determine the bending stress and use the formula σ = M / SM as before.
where;
All you have to do to find the height is plug in a value for 'x'.
Hi SteamKing,
Thank you for your help. Taking the cross-section at the wall I can calculate the bending stress at that point.
However, this led to more questions.
1) What would be the equation to determine the deflection at the very tip? I don't believe
δ=(FL3)/(3EI) since beam is tapered..
2) If I know the deflection needed, can I manipulate the deflection equation to obtain the force?
3) Would the moment of inertia change since taken at the very tip?
Again, thank you for your help..
d.saldana said:
Hi SteamKing,
Now you have found where things get more complicated with varying cross-section beams.
When I is no longer constant w.r.t. the length of the beam, the deflection equation must be re-derived from first principles, knowing the bending moment in the beam as a function of the beam loading and the position of the loads. In other words,
θ(x) = \frac{1}{E}\int^{L}_{0}\frac{M(x)}{I(x)}dx + C_{1}
δ(x) = \int^{L}_{0}θ(x)dx + C_{1}x + C_{2}
assuming that E, Young's Modulus, is still constant, and M(x) represents the bending moment as a function of the length coordinate. The two unknown constants of integration, C_{1} and C_{2} are determined by applying the boundary conditions of the cantilever known at the fixed end, namely the slope and deflection there are both equal to zero.
Now, you can assume a unit force acting at the tip of the beam and work out the deflection at the tip based on that force. Once you have calculated the deflection due to a unit force, you can determine the force needed to produce a given deflection at the tip using a simple ratio.
The two integrations need not be carried out symbolically unless you are interested; numerical integration can be used if you are only interested in what happens say, at the the tip of the beam.
OK, I see. I will work it out and see what I can come up with.. Thanks!
Hi d.saldana,
Greetings to you. I have the same query as yours. I tried a lot, but could not get the defection and bending stress equations.
I would like to know whether you got the solution.
I need help with this also, I have a tapered beam, and need to work out the theoretical deflection along intervals of x across the beam. I have the beam length, the butt diameter, the tip diameter, and the beam thickness. After that I have not a clue where to start, this forum seems to make sense to me but then i get lost when trying to implement what has been said into Excel
Please start a new thread for this . If this is homework then start your new thread in homework section .
Anyway we need to know more about the problem . Try sketching the beam so that we can see what shape it is and where the loads act .
  • · Replies 30 ·
  • · Replies 21 ·
