How Do You Calculate Deflection and Shear Stress in a Tapered Shaft?
This discussion focuses on calculating the deflection and maximum shear stress of a tapered shaft connected to a gearbox, specifically a propeller shaft made of 304 stainless steel. The shaft dimensions include a total length of 500mm, a diameter tapering from 35mm to 28mm over a length of 90mm, with a torque of 248 Nm at 200 rpm. The user is advised to differentiate between torsional and bending deflection, as the taper's effect on deflection is minimal, and to utilize the appropriate equations for each scenario, particularly the polar moment of inertia (J) and shear modulus (G) for torsional calculations.
  • Understanding of torsional and bending deflection principles
  • Familiarity with polar moment of inertia (J) and shear modulus (G)
  • Knowledge of material properties, specifically for 304 stainless steel
  • Basic mechanics of materials concepts
  • Research the equations for torsional deflection in tapered shafts
  • Study the calculation of maximum shear stress in materials
  • Explore bending deflection equations for variable section beams
  • Review mechanics of materials literature on tapered shafts and their behavior under load
Mechanical engineers, materials scientists, and students studying mechanics of materials who are involved in the design and analysis of tapered shafts and their performance under torsional and bending loads.
optzero
TL;DR
Tapered shaft equations for max shear stress and deflection
So i need a little bit of help with a problem.
I have a tapered shaft connected to a gearbox and i need to caluclate the deflection of the shaft and the max shear stress of the shaft.
the total length of the shaft is 500mm the diameter is 35mm and tapers to 28mm with the taper length of 90mm (so a standard 35mm taper). the material I am using is 304 stainless steel. as for the torque the torque on the shaft is 248 Nm and its spinning at 200rpm. for further context its a propeller shaft.
as for the deflection equation I am thinking of using the
d(theta) =(T/(J(X)*G)) dx
J is the polar moment of inertia and G shear modulus T is torque.
the above equation will give me the deflection in radians; is there an equation that will give me this deflection in mm?
what equation will i need to calculate the max shear stress the shaft can handle before failure?
any help would be great, and thanks in advance
Is this homework? If so, we can move it to the homework forum.
Is the shaft straight, with a taper at the very end for mounting a propeller? If so, analyze it as a straight shaft because the taper has minimum effect on the deflection.
Instead of looking for an equation with the right units, you need to:
1) Better define what you are trying to find out,
then
2) Find the appropriate equation.
There is a big difference between torsional deflection and bending deflection. You need to be clear on that in order to solve this problem.
Right, you will have to clarify whether you want to solve a bending or torsion problem (or maybe both). It all sounds like torsion but then you say that you are looking for deflection in mm which doesn't make sense in the case of torsion (there you only calculate the angle of twist). Torsion of a tapered shaft is a quite common topic in mechanics of materials literature so it won't be a problem. Bending of variable section beams is also discussed in various books so you should be able to calculate whatever you need rather easily.
12K
9K
