Taylor Series Expansion for the Relativistic Factor of Momentum
The discussion revolves around finding an approximate expression for the relativistic factor γ using Taylor series expansion, specifically for small velocities (v) around v = 0, aiming for an expansion correct to order v².
  • Participants attempt to expand the function γ(v) using Taylor series, with some expressing uncertainty about their expansions and the correctness of their derivatives. There are discussions about the substitution of variables and potential sign errors affecting the results.
The conversation is ongoing, with participants sharing their attempts and corrections regarding their series expansions. Some guidance has been provided about the derivatives and the correct form of the function, but no consensus has been reached on the final expression.
There are indications of typographical errors in the expressions shared, and participants are questioning the accuracy of their calculations and assumptions regarding the Taylor expansion process.
leejqs
Using the technique of Taylor expansion, find an approximate expression for the relativistic factor γ for small v (i.e., expanded around v = 0) that is correct to order v2.
γ=1/SQRT(1+ V2/C2). But in class, my professor just substituted X=V/C, so the equation became γ=1/SQRT(1-X2).
I tried to expand the function γ(v) with v at 0...
γ(v)=1+γ'(0)(X-0)+(1/2)γ''(0)(X-0)2
However, this expression wasn't correct. I'm not really sure how else to expand it! Any help would be much, much appreciated, thanks!
With that substitution, you get y = 1/sqrt(1 + x2).
This is really y(x) with x at 0. If v = 0, then x = 0. It's very likely that the sign error above is affecting what you got for your Maclaurin series.
Sorry for that typo! The actual function is y=1/SQRT(1-V2/C2).
In finding the parts of this maclaurin series, I have...
y(0)=1/SQRT(1-X2)(X-0)0=1
y'(0)=(1/2)(1-X2)(-3/2)*X2
y''(0)=(1/2)(1-X2)(-3/2)*X2+(1-X2)(-3/2)*(1-X2)(-5/2)*3X4
Sorry for my lack of showing my work, but I believe those expressions are right
when using the yn(v)=[f(n)(X0(X-X0)n]/n!
how to Put the Boolean function q'r + p'q' + pq'r' into DNF and find a simpler representation for the function using a Karnaugh map. Show the output of this simpler function is the same as in question 1 for p = 1, q = 1, r = 0.
Your derivatives are wrong because you're mixing in stuff from the series expansion. You should have:
[tex]y(X)=1/\sqrt{1-X^2} \rightarrow y(0)=1[/tex]
[tex]y'(X)=X/(1-X^2)^{-3/2} \rightarrow y'(0)=0[/tex]
and so on. You then plug these values for y(0), y'(0), y''(0) into the series expansion.
