Taylor series with summation notation
The discussion focuses on finding the Taylor series for the function f(x) = (1 - cos(x^2)) / x^3. Participants emphasize the importance of recognizing that the summation in the Taylor series can be manipulated, allowing x to be factored in or out of the series. A specific example is provided, demonstrating how to rewrite a related function using summation notation. The conversation highlights the need to separate terms effectively to simplify the problem. Understanding the Taylor series for cos(x) is crucial for solving the original function.
myusernameis
f(x) = \frac{1-cos(X^2)}{x^3}
which identity shoud i use?
and tips on this type of questions? once i can separate them, then i'll be good
thanks!
Do you know a Taylor series for \cos x?
yeah, but there's a x^3 on the bottom...
Sure, but the summation isn't over x so you can put the x in the sum or outside the sum.
Example:
\frac{1-\sin 2x^3}{x}=\frac{1-\sum_{k=0}^{\infty}\frac{\left( 2x^3\right)^{2k+1}}{(2k+1)!}}{x} = {\scriptstyle \frac{1}{x}}-{\scriptstyle \frac{1}{x}}\sum_{k=0}^{\infty}\frac{2^{2k-1}x^{6k+3}}{(2k+1)!}
= {\scriptstyle \frac{1}{x}}-\sum_{k=0}^{\infty}\frac{2^{2k-1}x^{6k+2}}{(2k+1)!}[/tex]​
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
