Staff Emeritus
2025 Award
- 22,723
- 7,826
Yes, the descent was made in the Trieste bathyscaphe.pinball1970 said:The depths, PSI are crazy there.
1960 tech was ok?
https://en.wikipedia.org/wiki/Trieste_(bathyscaphe)Trieste is a Swiss-designed, Italian-built deep-diving research bathyscaphe which reached a record depth of about 10,911 metres (35,797 ft) in the Challenger Deep of the Mariana Trench near Guam in the Pacific. On 23 January 1960, Jacques Piccard (son of the boat's designer Auguste Piccard) and US Navy Lieutenant Don Walsh achieved the goal of Project Nekton. It was the first crewed vessel to reach the bottom of the Challenger Deep.
A separate pressure sphere held the crew. "To withstand the enormous pressure of 1,250 kilograms per square centimetre (123 MPa) at the bottom of Challenger Deep, the sphere's walls were 12.7 centimetres (5.0 in) thick; it was over-designed to withstand considerably more than the rated pressure. The sphere weighed 14.25 metric tons (31,400 pounds) in air and eight metric tons (18,000 pounds) in water. . . "
The personnel sphere (gondola) is composed of a high strength steel described as a non-fatiguing chrominum-nickel-molybdenum [steel] alloy. The original (first) sphere was made by Terni (it was limited to a depth of ~20,000 ft (~6100 m), while a second sphere was made by Krupp Steel Works (had not depth limit!); ostensibly the same or similar alloy. The Krupp sphere was used in the deep dives.
https://apps.dtic.mil/sti/pdfs/AD0616288.pdf
From the Wikipedia article, "Trieste was fitted with a new pressure sphere in the winter of 1958,[5][6] manufactured by the Krupp Steel Works of Essen, Germany in three finely-machined sections comprising an equatorial ring and two caps, and by the Ateliers de Constructions Mécaniques de Vevey."
I cannot readily find the composition, but from the description, I suspect it is similar to HY-80.
https://en.wikipedia.org/wiki/HY-80
Dives of the Bathyscaph Trieste, 1958-1963: Transcriptions of sixty-one dictabelt recordings in the Robert Sinclair Dietz Papers, 1905-1994
https://library.ucsd.edu/speccoll/DigitalArchives/smc0028/Dives_Bathyscaph_Trieste_Dictabelts.pdf
Another historical document (1976) on the technology
https://seawifs.gsfc.nasa.gov/FRANKLIN/DOCS/Manned_Submersibles_by_R.Frank_Busby.1976.reduced.pdf
