Telescoping Method & Partial Fractions PLEASE HELP
The discussion focuses on solving the series sum from n=1 to infinity for the expression 2/(4n^2-1) using the telescoping method and partial fractions. Participants clarify that the correct partial fraction decomposition is 1/(2n-1) - 1/(2n+1), which simplifies to the original expression. There is confusion regarding the steps in the decomposition process, particularly the correct handling of factors and signs. Ultimately, the correct approach involves setting up the equation 2 = A(2n+1) + B(2n-1) to find the constants A and B. The conversation concludes with a participant expressing confidence in proceeding with the solution after receiving clarification.
BuBbLeS01
Telescoping Method & Partial Fractions...PLEASE HELP!
Find the sum of the series from n=1 to infinity...
2/(4n^2-1)
I want to use the telescoping method...
2/(4n^2) = 2/[(2n-2) * (2n+1)]
I am following an example in my book and this is where I don't know what they did next...but they got
An = 1/(2n-1) - 1/(2n+1)
Correct. And how do you write down the partial fraction decomposition when your denominator has two nonrepeated, linear factors?
BuBbLeS01 said:
2/(4n^2-1)...
Hi BuBbLeS01! :smile:
I'm confused … 1/(2n - 1) - 1/(2n + 1) is 2/(4n² - 1). :confused:
Next step … what is An + An+2 ? :smile:
Right, he's asking how the author got that result. So he needs to revisit partial fraction decomposition.
2/(4n^2) = 2/[(2n-1) * (2n+1)]
So the LCD for the right side would be (2n-1)*(2n+1)
2(2n+1)/(2n-1) + 2(2n-1)/(2n+1)
For some reason that doesn't look right though??
Hold on a second, you dropped a "-1" somewhere along the way. It should be this:
\frac{2}{4n^2-1}=\frac{2}{(2n-1)(2n+1)}
That's because it's not right, and I don't understand why you're writing it. What you're supposed to do is this:
\frac{2}{(2n-1)(2n+1)}=\frac{A}{2n-1}+\frac{B}{2n+1}
That ought to jog your memory enough to finish.
Hi BuBbLeS01!
That's because you've put a + in the middle instead of a - . :smile:
So is it just...
A = 1 and B = -1
:smile: Yes! :smile:
WOO-HOO LOL Thank you...I think I got it from here :)
  • · Replies 16 ·
