Telescoping Sum Convergence: Explained and Solved with Examples | Homework Help
  • Thread starter Thread starter Fuzedmind
    Issues Sum
The discussion focuses on solving a series expressed as a telescoping sum, specifically the series 2/(n^2 + 4n + 3). The initial attempt at partial fraction decomposition was incorrect, but a correct form was identified as 1/(n+1) - 1/(n+3), which allows for cancellation of terms. Participants demonstrated how to write out the first several terms to visualize the cancellation process. The key to finding convergence lies in identifying which terms remain uncancelled as the series progresses. The conversation emphasizes the importance of correctly applying partial fractions to facilitate the telescoping nature of the series.
Fuzedmind
The problem asks me to express the sum of the series as a telescoping sum, then find whether it is convergent or divergent. Ok, I get that and how it works and all, but the examples they give in the book are stupid and i on spring break this week so no office hours for professors.
Here it is:
2/(n^2 + 4n + 3)
I know, easy, but I don't get how to do it...the easy ones stump me.
I rewrote it like this:
(1/2)(2/n+3) - 2/n+1)
But the terms do not cancel when I do this. Plus it is an even question so I do not know the solution.
Fuzedmind said:
..but the examples they give in the book are stupid and i on spring break this week
I can tell :smile:
You didn't do the partial fractions right; This is apparent by plugging in n=0 to the original and what you got: \frac{2}{n^2+4n+3}=\frac{1}{n+1}-\frac{1}{n+3}. These terms WILL cancel at some point. Write out the first 5 or so terms of the series and you will see this.
Well I did that, and they started cancelling, and I got
(1 - 1/3) + (1/2 - 1/4) + (1/3 - 1/5) + (1/4 - 1/6) + (1/5 - 1/7)
I canceled the 1/3, 1/4, and the 1/5 out, but where do I go from there?
Sorry I am kind of retarted
Now write a few more terms and cancel the 1/6 and 1/7. What terms don't cancel? I kind of have faith that you aren't THAT retarded.
What you want to do is make sure that, for each "-1/(n+1)", there exist an m so that its "1/(m+3)" cancels it. That is, given an integer n, what m will make 1/(m+3)= 1/(n+1)?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
