Air Pressure & Temperature: Is the Relationship Correct?
Higher temperatures correlate with lower air pressure, while lower temperatures lead to higher air pressure. When warm air rises, it expands and creates a less dense air mass, resulting in lower atmospheric pressure. Conversely, cooler air sinks and contracts, increasing density and leading to higher pressure systems. This relationship is explained by the Ideal Gas Law, which indicates that if pressure is constant, an increase in temperature results in decreased density. The discussion also clarifies that weather systems labeled as high pressure are typically associated with warmer temperatures, while low pressure systems are cooler. The concept of air masses is explored, highlighting that they can expand and displace surrounding air, contributing to wind and pressure changes. Understanding these dynamics requires knowledge of fluid mechanics and thermodynamics, as they involve the interplay of temperature, pressure, and volume in the atmosphere.
7bear
Higher the temperature, lower is the air pressure.
Lower the temperature, higher is the air pressure.
Are they right? If yes, why? :confused:
In general, I think that this is correct. A warm air mass will rise and expand. When this is happening over you, the local atmospheric pressure is therefore lower. I'm guessing it's simply because you have a less dense air mass over you. Therefore it weighs less and exerts less pressure. Come to think of it, it's like suddenly having fewer air molecules per unit volume. Just as if this were happening in a container, the pressure would decrease.
Likewise, a cooler air mass will sink and contract, becoming more dense. I'm quite sure that when that happens in your area, it's referred to as a high pressure system.
Is my assessment correct?
is this in a test tube, or the whole world?
you should give more deatail , casue this will leads to several answers
Actually, the exact opposite is true about what you said. First of all, pressure increases with temperature, and increasing pressure or temperature causes density to go down. Hence why hotter air rises and cooler air sinks. In fact a "high pressure system" that they refer to in forcasts always have higher temperature, and low pressure systems always have lower temperature. According to the Ideal Gas Law...
PV = nRT
Where P = pressure, V = volume, n = moles, R = ideal gas constant, and T = temperature
As you can see, when pressure increases if volume and moles is kept constant, then temperature must increase as well.
You can manipulate the equation to see the effects on density...
n = \frac{m}{MM} Where m = mass, and MM = molar mass
PV = \frac{mRT}{MM}
P = \frac{DRT}{MM} Where D = density
D = \frac{P(MM)}{RT}
From this, it is clearly seen that if pressure is kept constant, increasing temperature must make density decrease
Actually, it is much easier to see the relationship between P, V, and T by using the Combined Gas law...
\frac{P_1V_1}{T_1} = \frac{P_2V_2}{T_2}
See for yourself by pluging in numbers.
Actually, if you look at weather forecasts, its the other way around.
Yeah, actually. I'm really confused about this after reading everyone's answers. I admit I must have been wrong, but what I'd like to know is what's meant by high pressure and low pressure weather systems.
Classroom explanations are kind of weird because they talk of an "air mass" being warmed, expanding, rising, and cooling. I'd also like to know: if we're surrounded by a sea of air, what differentiates one particular air mass, and how can it "expand" without displacing air around it? :confused:
Thats the thing, it DOES displace those around it, hence "wind".
Imagine the air as a bunch of balloons filled up that can be compressed or inflated, heated (wont melt), but let's keep the AMOUNT of air particles "n" the same. We then have idea gas law :
PV ~ T
So if you increase the temp of one balloon, for its pressure to remain at equillibrium it increases its volume. This forces all the surronding balloons to shrink, which make them warmer, because as V drops, P increases and so does T. See, everything is trying to be in equillibrium, heat and pressure, so it balances itself out. By transfering heat to a colder balloon, the pressure in the hot balloon drops. Really its fluid mechanics of the changes of pressure, where if you don't know applied mathematics for fluid dynamics its hard to understand.
Also remember wind is mainly from bernoulli's principle, that there's a force normal to a pressure gradient. This also means there's a force(in air) to a temperature gradient. Basic thermodynamics.
