Replacing Temp Controller: What to Look For?
When replacing a temperature controller, key properties to consider include the type of temperature sensing element (RTD or thermocouple), control method (on/off or proportional), and compatibility with the existing system. Understanding the application is crucial for selecting the right controller, as it influences the specifications needed. Users suggest cross-referencing with similar controllers in stock and gathering technical references related to temperature and heating. Additionally, knowing the specifics of the previous controller, such as wiring configurations and operational characteristics, can aid in making an informed choice. Ultimately, selecting the right temperature controller requires careful consideration of these factors to ensure proper functionality.
EEFinder
I am trying to replace a Temp. Controller that is no more produces anymore.
What are the controller properties/settings/ that I have to pay attention to. in another word, what to select a temp controller for certain application?
Thanks.
What did you have before and what are you hooking it to?
this was dumped on me today,
the original controller was "ripped" for the application (industrial heating pad), long time ago. so there is no way to know which one goes where, meaning that no documentation what so ever of which wires go to the RTD, control, and power... is available.
I am thinking about cross referencing the original controller with something that I will have in stock.
to do this I wanted to know what should consider in a controller for it to go with my application.
Thanks.
Thanks of the Reply.
you see just for the sake of analogy, if someone asks about what to look for in selecting an electric motor, I would answer RPM, current, Voltage,Frame, HP,
I am looking for similar answer, but using Temp Controller instead of the electric motor. I know 2 so far that are the voltage and the Temp Sensing element (RTD, TC..) and wondering what the others are?
Hope this makes sense
EEFinder said:
... in another word, what to select a temp controller for certain application?
Well, know the application helps to know in order to answer such a general question. But Okay. 4-20 ma loop?
OK http://www.grainger.com/product/OMRON-Digital-Temprature-Controller-WP135543/_/N-8h2?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/4YE30_AS01?$smthumb$
form, fit, function
What do you know about the one that's no longer there ?
First question is this an on off controller or a proportional device?
  • · Replies 46 ·
  • · Replies 18 ·
  • · Replies 17 ·
