Temperature effect on magnetism.
  • Context: Undergrad
  • Thread starter Thread starter sallyedmonds
    Magnetism Temperature
The discussion centers on the temperature effect on the magnetic properties of mild steel, specifically its permeability and behavior at the Curie point of approximately 750°C. Participants clarify that while mild steel exhibits ferromagnetic properties below this temperature and paramagnetic properties above it, the magnetic permeability does not gradually decrease with temperature. Instead, it remains constant until the Curie point is reached, where the material transitions from ferromagnetic to paramagnetic. The conversation emphasizes that magnetic permeability is independent of temperature changes within the context of mild steel.
  • Understanding of ferromagnetism and paramagnetism
  • Knowledge of Curie's Law and Curie point
  • Familiarity with magnetic permeability concepts
  • Basic thermodynamics related to material properties
  • Research the relationship between temperature and magnetic properties in different materials
  • Explore Curie's Law and its implications for ferromagnetic materials
  • Investigate the concept of magnetic permeability in various compounds
  • Examine experimental methods for measuring magnetic permeability at varying temperatures
Physicists, materials scientists, and engineers interested in the magnetic properties of materials, particularly those working with ferromagnetic and paramagnetic substances.
sallyedmonds
The curie point for mild steel is about 750deg C. Before this temp it is ferromagnetic and after that temp its paramagnetic i think. But my question is does the magnet permiabilty of the mild steel gradualy reduce as it gets hotter up to that temp?
If we say Mild steel permiability is 100% at 20deg C what percentage would it be at say 400deg 500deg 600deg...
Is there a graph we can plot that show this? or is it 100% up to749Deg and then suddenly bang its not?
Hope you can help
Sally
I believe that the magnetic permissibility of steel (or any other compound) is constant.
Also, I do not believe that magnetic permeability has anything to do with magnetization temperature (ie your 750 deg C example). Neither curie's law, or the equations for curie's constant include permeability as a variable.
Magnetic permeability is a measure of how easy it is for magnetic fields to pass through materials. Some materials have high permeability, and can transmit magnetic fields quickly; and others have low permeability, transmitting incident fields slowly.
While steel's ferromagnetic and paramagnetic properties can be changed with temperature, I do not believe its permeability is.
  • · Replies 26 ·
9K
  • · Replies 19 ·
