How Can I Calculate the PSI Needed to Compress Air to 100°C?
The discussion focuses on calculating the pressure (psi) required to compress air to 100°C using thermodynamic principles. The Ideal Gas Law (PV = nRT) is central to this calculation, along with the understanding of adiabatic processes. For an adiabatic process involving diatomic gases like air, the pressure can be determined using the equation Pf = Pi(Vi/Vf)^gamma, where gamma equals 1.40. The conclusion states that to achieve a temperature of 1000°C, the pressure must be increased to 2,513 psi starting from atmospheric pressure.
  • Understanding of the Ideal Gas Law (PV = nRT)
  • Knowledge of thermodynamic processes, particularly adiabatic processes
  • Familiarity with the concept of absolute temperature and conversion to Kelvin
  • Basic grasp of polytropic processes and the polytropic index (n)
  • Research the application of the Ideal Gas Law in various thermodynamic processes
  • Learn about the implications of adiabatic compression on temperature and pressure
  • Explore the derivation and application of the polytropic process equations
  • Investigate the effects of different gases on compression ratios and thermal properties
Engineers, physicists, and students in thermodynamics or mechanical engineering who are involved in gas compression and thermal energy calculations.
matthewgill
Hello,
We all know that if you compress air the pressure and temperature increase together.
But how can I calculate the relationship?
For example: What pressure (psi) do I need to compress air to so it is 100degC?
Many Thanks,
Matthew.
Science news on Phys.org
The equation is PV = nRT
P = pressure
V = volume
T = temperature
n = the amount of gas, if you don't ad or remove any you can ignore this.
R = a constant to get all this in the correct units.
So basicaly PV/T is the same before and after and as long as you use the same units it all works.
Remember to do this in terms of changes in temperature. If you want this in absolute temperature you need to convert to Kelvin (google absolute temperature)
In Thermodynamics there are different fundamental THERMODYNAMIC PROCESSES namely Isobaric, Isthermal, Isentropic, and Polytropic and Isochoirc processes.
Each of these processes has its own unique method of heating or cooling of the air/gas depending on the boundary conditions or type of surrounding or keeping some fundamenrtal parameters like pressure, tempreature, volume or entropy a constant.
Depending on the typr of process chosen the values and relations between the pressure, tempreature ( as menioned in your case) will vary.
The basic equation is the Ideal Gas Equation PV = mRT which remains applicable in all cases in any process.
But there are another set of equations derived from the above ie PV^n = C, where n is called the polytropic index, and all the above processes have a particular value of n. And depending on this value of n for each process the amopunt of heat or pressure required to heat up or compress air to a particular value will depend on or vary.
It all depends on your choice of process and the variables will change according to the particular equation.
P = pressure
V = volume
T = temperature
OK, this is true for isothermal condition. For an adiabatic system, the temperature increases when you compress air. I should think there is a relation between the temp rise and pressure ratio (before and after compressing)
pixel01 - you have the right idea.
i have found this, which is what I am trying to do. I just need to know the psi required for 100degC rather than 1000degC. Can anyone help change the equation?
QUESTION
What compression ratio Vmax / Vmin will raise the air temperature from 20C to 1000C in an adiabatic process?
the gas is diatomic
ANSWER
For an adiabatic process, with Q = 0, the first law of thermodynamics is:
Change in thermal energy = Work. Compressing a gas adiabatically (W > 0) increases the thermal energy. So an adiabatic compression raises the temperature of a gas.
gamma = 1.40 for a diatomic gas (like air)
Pf = Pi(Vmax/Vmin)^1.40
Wait a minute:
(Tf) Vf^(gamma - 1) = (Ti) Vi^(gamma - 1)
(1,273K)Vf^(gamma-1) = (293K)Vi^(gamma -1)
(1,273K) Vf^0.4 = (293K) Vi^0.4
1,273K / 293K = Vmax^0.4/Vmin^0.4
4.3447 = (Vmax^0.4 / Vmin^0.4)
(4.3447)^2.5 = (Vmin^0.4 / Vmax^0.4)^2.5
Vmax/Vmin = 39.346
So you would need to increase pressure to 2,513 psi if you started from atmospheric pressure.
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 28 ·
