Temperature of fluid flowing through pipe
178 replies · 43K views
Okay I will go with BSL. It's just that I am doing something like this for the first time. I usually assume physics has exact equations for given situations. I will be back if I have questions.
Thanks Chet.
Thanks Chet.
Welcome to the world of experimental correlations of data.
Chet
Hey Chet. This is good.
However, my professor has asked me to include the coolant heat transfer estimation into the project too "if I can".
Now, I want to put some effort into it. I am using an OBD data logger and so I am going to have the coolant temperature with me directly. So, the only things I really want would be :
1. Coolant mass flow rate
2. Coolant specific heat capacity
Have you any idea of equations on these? I searched Perry, and the Graduate Naval school document they don't have specific heat capacity of Ethylene glycol solution as a polynomial in temperature. But I could use this and create a function in MATLAB :
http://homepage.usask.ca/~llr130/physics/HeatCapcityOfAntiFreeze.html
I am going to assume a 50%-50% solution (so 4th column), I think that would be good. But let me know if I am wrong.
How would I estimate the flow rate? I read a thread here in physics forums, and also another site. I don't find anything conclusive.
See following Engineering Toolbox link for properties of antifreeze:http://www.engineeringtoolbox.com/ethylene-glycol-d_146.html
Also see:
http://www.arrowheadradiator.com/coolant_&_radiator_service.htm
https://www.google.com/search?q=coo....69i57j0l3.15267j0j4&sourceid=chrome&ie=UTF-8
A typical coolant circulation rate is 5 gpm, but, of course, it depends on the engine speed.
Here's a Physics Forums thread on coolant flow rate (lots of good meaty info for you): https://www.physicsforums.com/showthread.php?t=566125
Chet
I am going to be acquiring the engine rpm from the OBD data logger as well.
Since, the OBD data logger gives me both the engine rpm as well as the coolant temperature, I don't need to find the heat transfer coefficient or all the other things. Because I have the temperature of the coolant, and I need the energy of the coolant. So its directly plugging it into the equation for rate of heat.
I can make a function for the specific heat capacity of the coolant from those links. So, if I have the mass flow rate, I have everything I need.
So, what would the exact relation between the coolant circulation rate and engine rpm be? The link doesn't give me that even if it gives me a rule of thumb in the second post (what's the source?).
I didn't keep track of the source. I just Googled Coolant Flow Rate, and this was one of the choices.
If one is serious about getting the coolant circulation rate, one needs to know the so-called pump characteristic. The water pump in a car is a centrifugal pump, and the characteristic tells you the volume flow rate through the pump as a function of the pressure buildup across the pump and the rotation speed. This information usually is supplied by the pump manufacturer.
Is there any way you can just measure the water flow rate in the inlet and outlet lines to the radiator?
Chet
Chet
No, as of now its too late to get into acquiring those data. I guess I will tell him there is nothing certain I could find on the flow rate of the coolant.
If you had the pump characteristic of your particular water pump (maybe it's available on line) and you could measure the pressures into and out of the radiator, you could get the flow rate. However, I guess there's not enough time to do this.
Chet
There is time to do calculations based on characteristics we acquire from manuals, or standard values. There just isn't time to buy any new instrumentation systems, and program them.
The car I am using now is a Ford F-150. The reason my professor wants the coolant energy is to use it as a standard to compare if the model got the exhaust gas energy within acceptable values.
A lot of literature gives us the ratio of the exhaust gas energy to the coolant energy. So, even if we have rough values of the exhaust gas energy or coolant energy for a vehicle like the Ford F-150 we can compare those values to see if the model is right.
Hi Chestermiller, something terrible has happened. We aren't using the temperature sensor, but only the OBD data logger and we are acquiring the following parameters directly - vehicle speed, coolant temperature, engine rpm, throttle position and air flow into the tank. I feel terrible for wasting your time.
So, there is no exhaust temperature! And today we tried fitting the temperature sensor under the exhaust pipe and my professor just said, we don't need it. This has really upset me, because I feel he should have let me know about this as I was putting efforts on it.
So basically all my efforts in programming my sensor for the past 2 months, and this whole discussion for the past 7 months are as good as nothing (but it was a good learning I had, thank you).
Since, I do need the exhaust temperature OR the coolant flow rate. I would like to ask you if there is any way to model the exhaust temperature FROM the coolant temperature, or get to the coolant flow rate.
Data I have logged (inputs) :
1. Vehicle speed
2. Coolant temperature
3. Engine rpm
4. Air flow
5. Throttle position
Now, we are using a Ford F-150 Triton V8 engine, model 2002. I will try finding the exact pump or part you need the specs for. But the above 5 are the only changing parameters I have. The logger only allows for 5 parameters to be measured at a time. I will list other parameters, tell me if they are important to our calculations. I felt the above 5 are important.
Assuming we have the above 5 logged, and also using certain unchanging parameters what is the best way to model this? Even if we just found coolant flow rate, OR temperature of gas, we are fine. Any one from the above 5.
Jay_ said:
I need to work quickly. Because I have to complete it by the end of this month.
I found this online :
http://www.fordservicecontent.com/F...ner's-Manual-First-Print_om_en-us_09_2013.pdf
But it says nothing about the radiator hose or pump. I can't find it in the index.
Hi Jay.
This is really bad news. I don't know what your professor's ultimate objective is, but I am assuming it is to determine how much energy is available from the fuel air mixture once you subtract the energy exiting the exhaust and the cooling system (radiator). Of course, not all this energy is available as drive power, because there are losses due to friction, running the fuel pump, running the water pump, running the air conditioner, running the oil pump, etc.
As we said, you know the exhaust flow rate and composition, but not the exhaust temperature. The problem is, you can't determine the energy exiting the exhaust without knowing the exhaust temperature.
As far as the cooling system is concerned, you could be in a little better shape if you could estimate the coolant flow rate. When you say that you know the coolant temperature, I am assuming you know it at the entrance to the radiator. Any chance you also know it at the exit? As far as the coolant flow rate is concerned as a function of the engine speed, the reference you sent (owner's manual) is of no use. But, you may be able to find more information in the Shop Manual. Shop manuals are available on line and also may be in the library. There is also the effect of the thermostat to consider. The thermostat, I think, controls the fraction of the coolant the bypasses the radiator, and is keyed to the coolant temperature coming out of the water pump.
Chet
Yes. I need you through this sir. The objective of this project was to estimate the energy that is wasted in the form of heat through the coolant and the exhaust. Initially, my plan was to work with the exhaust energy and since literature tells me the ratio of energy wasted between the two, I could estimate the energy wasted as heat through the coolant.
Now I checked my data logs the coolant temperature seems to just vary mildly - from 84 deg C to 91 deg C, over a wide range of speeds (0 to 120 kph). Given that this is roughly constant, I am assuming my logger is actually measuring the cooler temperature.
Now, if we could model the hotter temperature as a function of the above 5 inputs, and also the flow rate as a function of the engine rpm, or get these from literature, we will be done.
My first thought is, since the cooling in the radiator hose is radiative, could the Stefan-Boltzmann law come to help in estimating the temperature at the other end?
Yes. That's the outlet temperature from the radiator.
No. Even though it's called a radiator, the mode of heat transfer is convective.
Chet
The fan gives it a forced cooling though right?
How are we modeling it? Is it even possible with the 5 parameters I listed? Let me know if I have to find any particulars about the car.
Hey Chet,
I got an idea. Since my professor wants to know if the values I get are real, and literature tells me that around 33% of the energy is lost through the exhaust, I am just going to compare the value I get of the exhaust to the total energy based on the calorific value of the fuel burned.
I have the distance traveled in my logger. I have the mileage of the car for a given drive cycle. I can thus find out how much fuel gallons I used, and thus the grams (from the density). Based on that and the calorific value, I can find how much energy was used in total.
Then I have to show that the energy given off from my model is roughly 33% of this total, which is basic math. Is this reasoning sound? If it is, I have to speak to him about it, because I would prefer that all the efforts of the past many months don't go in vain. I also have a friend who has a car, and he is willing to help me with placing the sensor under the car.
Many cars don't have enough ground clearance, the Ford F-150 we used earlier had a exhaust pipe arrangement that was difficult to have a sensor on, there was no position for it, and also the pipe split as two at (beginning point) where we wanted to set it up. Now I am using a Nissan Maxima, and hopefully it gets done!
Jay_ said:
Hey Chet,
I'm a little confused. The sensor is back in the picture again?
Chet
Hi Chet,
Yes. I couldn't let all that work go waste. So I used my friend's car and we got some temperature data of the pipe. We had to do a city drive cycle and also a highway drive cycle.
The temperature sensor stopped sending data in the highway for some reason, so I only got some of it. The thing is I needed to use the temperature sensor, because I have already typed 20 pages on the report over the model and the sensor.
But since I have the 5 data from the OBD data logger (engine speed, coolant temperature, vehicle speed, air flow, and throttle). We need to model the coolant quickly and use the coolant temperature data on that. Even a rough estimate is good for modeling the flow rate and the cold-side temperature.
Okay. I would but the units on the y-axis are unclear. Also it says cm^3/cycl would that mean for a 6 cylinder, I would have to times the value with 6.
I tried searching for another graph, and I feel unsettled whenever I come across information that contradicts. Look at the one I found, it seems to show that the flow rate increases with engine rpm almost linearly. Do these contradict or have I misunderstood?
If they do, which would be the better one to go with?
http://files.engineering.com/getfil...34-bc19-41780227b743&file=cooling_montage.jpg This one is for a V8 though.
The y-axis in the Howarth plot is dimensionless, and is the ratio of the radiator heat load to the brake horsepower at spec RPM. Consider this reference:
http://www.arrowheadradiator.com/14...apability_in_high-performance_automobiles.htm
It has info similar to the Howarth plot, saying that y is about equal to 1.0, as a rule of thumb.
The plot is suggesting that the heat load is nearly constant over a wide range of engine speeds. This implies that, as the engine speed increases (and as the coolant flow rate increases), the temperature drop in the radiator decreases nearly inversely. Your other graph shows the coolant flow rate through the radiator increasing with engine speed. I would assume that the coolant flow rate is nearly directly proportional to the engine speed, as suggested in your other plot.
Chet
So, the graph from the physicsforum page isn't useful unless I know the bhp at each rpm right? Because that is the only way I could calculate the flowrate.
I am hesitating to use the other graph because its for a V8. But if I find nothing else, that is what I would have to go with given that I have 8 days left.
Hey Chet,
Let me know if the following is a correct way to go:
The graph in the other physicsforum thread gives me the decimal number to multiply with the horsepower right? Now I am using 2007 model, so that is 6th generation and this graph below gives me the horsepower with respect to rpm. But my engine size is bigger 3.5 L would it make a big difference?
http://home.comcast.net/~stevtecv6/dynos/NHT_30V6_HP_MD_j30eststock.jpg has
Hey Chet,
http://home.comcast.net/%7Estevtecv6/dynos/NHT_30V6_HP_MD_j30eststock.jpg (Link 1)
has the wheel horsepower I believe.
So the break horsepower would be 15% greater (or I might take 22% from the middle of 20-25% in the note below) from this link :
http://www.carthrottle.com/the-difference-between-bhp-and-whp-explained/ (Link 2)
I go to Link 1, but to convert the wheel horsepower to brake horsepower, I go to Link 2. I then multiply it by the corresponding number in the ordinate of the graph in the physicsforums thread.
Is that reasoning good?
No. From the engine specs, you know the horsepower at a specified RPM. You use this to find where your engine's curve should lie within the shaded area. Then, for that bhp, you know the heat load at all speeds. This inherently assumes that your car's curve really does lie within the shaded area.
Once you know the heat load at the specified engine speed and bhp, you can measure the temperature change at that engine speed and back out the coolant rate. That will give you the proportionality constant between the coolant rate and the engine speed.
[/QUOTE]
Jay_ said:
Hey Chet,
Yes. I think that this makes sense to me. But please understand that, like yourself, this is also out of my range of experience. You really need to rely more on your own judgement at this point. If you still don't feel confident, you need to do some more background reading in an automotive engineering text. It's particularly important to understand what the various terms mean, e.g., brake hp.
Chet
Hi again Chet,
I have been successful in making equations for those graphs based on interpolations.
1.I get a wheel horsepower value for a given RPM, I multiply by 1.22 (because 22% is lost in going to the wheel, so I work backwards) and that gives me the brake horsepower at a given rpm. What is value of flow rate if the ordinate in that physicsforum link is say 0.8, what unit is it?
2.Also, do I have to multiply the value with 6 because it is given as flow rate/cyl? And I understand this is the volumetric flow rate I will have to multiply it by the density to get the mass flow?
Also I want to cite the book by Howarth (probably go through it a little bit), what is its name?
