Converting Between Temperature Scales: Finding the Relationship Between M and F
The discussion focuses on converting between two temperature scales, M and F, highlighting a miscalculation in the relationship M = 2F. Initial calculations show that 437°M corresponds to 212°F and 77°M to 32°F, leading to the incorrect conclusion that M equals twice F. A suggestion is made to create a linear plot of M as a function of F to accurately determine the correct conversion, particularly for the 68°F point. The correct conversion for 68°F is identified as 149°M, indicating that the initial relationship does not hold true across the entire scale. Accurate temperature conversions require careful consideration of the endpoints and linear relationships.
NP04
Unsatisfied with the Celsius and Fahrenheit temperature scales, you decide to create your own. On your temperature scale, the ice point is 77° M and the steam point is 437° M, where M stands for "my scale." What temperature of your scale corresponds to 68°F?
Not sure, because I think you have to make your own equations.
I found the relationship M = 2F, but got the wrong answer.
MF
Ice Point77°M32°F
Steam Point437°M212°F
437°M - 77°M = 360°M
212°F - 32°F = 180°F
∴ M = 2F
M = 2(68°)
M = 136°
But this is incorrect. The answer is actually 149°M. Please help.
Do a careful conversion from, say, F to C, and observe the steps. You'll see what you left out on this calculation.
Likes Vanadium 50
Does this relationship work for 32F? For 212F?
If the answer is "no", do you think you should trust it?
Likes berkeman and phinds
Hint -- make a simple 2-D linear plot of M(F) (M as a function of degrees F). You know both endpoints of the straight line between Freezing and Boiling in both M and F, so now you can find where the 68F temperature point is on the M scale. Makes sense?
12K
  • · Replies 16 ·
9K
