Tension In Rope: Box Suspended & Pulled by Force
  • Thread starter Thread starter Hamza Abbasi
    String Tension
When a box suspended by a rope is pulled to one side by a horizontal force, the tension in the rope increases due to the balance of forces acting on the system. The applied horizontal force creates a reaction that must be countered by the tension in the rope, which supports the box. This relationship can be described using force balance equations, which illustrate how the tension adjusts to maintain equilibrium. The concept of action and reaction explains that the rope experiences increased tension as it compensates for the external force. Understanding this dynamic is crucial for analyzing forces in suspended systems.
Hamza Abbasi
A box suspended by a rope is pulled to one side by a horizontal force. The tension in the rope increases! Why is it so?
draw a diagram; write down force balance equation; expand it in coordinate frame if needed
Have you solved the force balance equations, as zwierz suggests, and found that the tension increases, or were you told that it increases and you're trying to understand why?
Because for every action if force there is an equal and opposite reaction. Thus this equal reaction must get exerted upon the rope, as it is supporting the object on which the force was exerted. Ergo...more tension on the rope.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
