Tension on Rope, greater then, less than, or equal to
The discussion revolves around understanding the tension in ropes under different conditions. It emphasizes that if an object is not accelerating, the forces acting on it must be balanced, with the upward force equal to the downward force (Mg). When two ropes are involved, the tension in each rope is determined by the distribution of the total force, which must equalize to prevent acceleration. Additionally, the tension will vary between ropes depending on how many masses each rope supports, with one rope potentially having greater tension due to supporting two masses. The conversation aims to clarify these concepts and ensure the accuracy of the answers provided.
isaac206
https://auddoq.dm2302.livefilestore.com/y2mGb2n5mfKxwU4nZlLmOvyElgDcG0-5GG9dGoP4AbrV1taK31XrOoPmeyf9x9RQZ8kXLi0WG2Etd0-I8bVWqOgVufahONs02hTGFS-SUwBVRyd-ajz5Eza-nrk9yWa7kF6kPFtMdPD6MGIpfwQMhywCLfOOuIO4-3tLe1_KjSf9V0/20150505_234057356_iOS.jpg?psid=1
if the image does not show here's the link: https://onedrive.live.com/?cid=145f...v=3&ithint=photo,jpg&authkey=!AIYbbkhjjxVZgWk
I need help with question, i understand F=m*a and all that.
I will help with a few of these..
Top left: If the object is not accelerating, that means that the forces must be balanced, to ensure no acceleration. If the force pulling the object down is Mg, then what force would have to be pulling upwards? What provides this force?
Middle left: If the same force is pulling down as the problem above it, but the force is presumably equally distributed between two ropes, what do you think the tension will be on each rope, knowing that the total force upward must equal the total force downward in order to keep the mass from accelerating?
Bottom left: Which rope has greater tension? Why? Keep in mind that one of the ropes needs to support two different masses, while one only supports a single mass.
I will be happy to answer any more specific questions.
Likes isaac206
Thanks for the help, other than the 3 you helped me with are there any others that are incorrect? You don't have to give me the answer I just don't want to change any correct answers and spend all day on the question.
