harrylin said:
According to GR, the inertia of bodies is greater near masses.
https://en.wikisource.org/wiki/Geometry_and_Experience
Has this been tested? I did not find a clear answer, the gravity tests seem to be testing other things. Can it be tested?
Before asking whether it can be tested, we need to be clear about what it means. I realize this is Einstein again, and he did say "the general theory of relativity teaches" this, so you're taking it as gospel, but here's how modern GR would rephrase what Einstein said:
The presence of "ponderable masses" (i.e., a nonzero stress-energy tensor) in a spacetime determines what the inertial frames are at any point of that spacetime: in other words, it determines which states of motion are "inertial" (freely falling) and which are not. Since any object with no forces acting on it other than gravity will move on a freely falling worldline, if we take that object at a particular event, and we know its initial velocity at that event, we can predict its entire trajectory just by knowing what "ponderable masses" are around.
Near a large mass, like the Earth, the local inertial frames--i.e., the freely falling states of motion with some given initial velocity--"point in a different direction" than they would in a region with no large mass nearby; the local inertial frames point inward, towards the large mass. That is what Einstein meant by saying that the large mass "increases the inertia" of objects.
On this view, of course, we already have a huge pile of experimental evidence that says that ponderable masses do "increase inertia". But there's more. What if the ponderable mass is rotating? It turns out that GR in this case predicts an *extra* effect of the nearby mass, called "gravitomagnetism", which should, for example, affect the orbital parameters of satellites orbiting a rotating planet, as opposed to a non-rotating one. This has actually been measured:
http://archive.sciencewatch.com/dr/fmf/2011/11janfmf/11janfmfCiuf/
This is significant because it is purely a GR effect; it does not appear at all in Newtonian gravity, and yet it still confirms the idea that the matter in the Earth is determining the local inertial frames near the Earth.
(Btw, Cuifolini, who headed up the research described in the linked interview, wrote a book with John Wheeler called
Gravitation and Inertia which goes into great detail about this whole issue of what determines inertia, Mach's Principle, is GR "Machian", and so on. It's a difficult read in many places if you're not familiar with the math, but it does have some good discussion of these issues that can be followed without knowing the mathematical background.)
