Testing Understanding: Conformally Flat Space-Time
15 replies · 2K views
Markus Hanke
As an amateur, I am just testing my understanding on the following, since there is nothing worse than harbouring misconceptions.
Suppose we have a space-time ( e.g. of FRW type ) which is conformally flat :
[tex]C{^{\mu \nu }}_{\rho \sigma }=0[/tex]
but not Ricci flat : [tex]R_{\mu \nu }\neq 0[/tex]
Would that physically mean that, if I was to release a ball of test particles in such a space-time, that ball would retain its spherical shape along its geodesic, but either increase or decrease its volume ?
Just wanting to confirm my understanding on this. Thanks in advance !
Also - and I'm not sure if I should open another thread on this - I am aware that the contraction of the Weyl tensor across two of its indices always vanishes ( i.e. it is trace free ). I can see why that would be the case purely algebraically, but I'm not sure about the physical significance of this - does it simply mean that Weyl curvature preserves volume, in a manner of speaking ?
Yes. [Edit: yes to the volume increase/decrease. The shape question is more complicated, see follow-up posts in this thread.]
Yes.
Great, thank you !
No.
If the geodesic congruence has a 4-velocity ##\xi^a## then for vanishing Weyl tensor the shear evolves according to the following: [tex]\xi^c \nabla_c \sigma_{ab} = -\frac{2}{3}\theta \sigma_{ab} - \sigma_{ac}\sigma^{c}{}{}_b - \omega_{ac}\omega^c{}{}_b + \frac{1}{3}h_{ab}(\sigma^2 - \omega^2) + \frac{1}{2}\hat{R}_{ab}[/tex] where ##\theta## is the expansion, ##\omega_{ab}## is the twist, and ##\hat{R}_{ab}## is the spatial projection relative to ##\xi^a## of the trace-free part of the Ricci tensor. Clearly this is non-zero in general, even if we demand that the geodesic ball have vanishing twist. C.f. Wald section 9.2.
WannabeNewton said:
No.
No to the part about retaining spherical shape, correct? If the Ricci tensor is nonzero, then the volume of a small ball of test particles will have to change. In other words, the expansion of a timelike geodesic congruence must be nonzero if the Ricci tensor is nonzero. (More precisely, ##\dot{\theta}## must be nonzero, which means that ##\theta## can't be zero for more than an instant.)
WannabeNewton said:
No.
Ok, I see that my understanding must be off somewhere. Unfortunately I haven't studied Wald ( it's been sitting on my shelf for the past three years or so - it seems like a very "heavy" text for an amateur ), so I am finding it hard to make ( geometric ) sense of the expression above - what physical significance can I attribute to the non-vanishing shear ? In other words, in what way exactly would the shape of the ball change along its geodesic ? How can I visualise that change ? Also, what is [tex]h_{ab}[/tex] in the above expression ?
I appreciate all your help !
Markus Hanke said:
Ok, I see that my understanding must be off somewhere. Unfortunately I haven't studied Wald ( it's been sitting on my shelf for the past three years or so - it seems like a very "heavy" text for an amateur ), so I am finding it hard to make ( geometric ) sense of the expression above - what physical significance can I attribute to the non-vanishing shear ? In other words, in what way exactly would the shape of the ball change along its geodesic ? How can I visualise that change ? Also, what is ##h_{ab}## in the above expression ?
##h_{ab}## is the spatial projection tensor ##g_{ab}+\xi_a \xi_b## where ##\xi^\mu## is a timelike congruence. ( I'm not sure about the sign there).
The expression is the rate of change of the shear tensor ##\sigma_{ab}## projected in the direction ##\xi^\mu##. I have to admit I would like some explanation.
If we have a rigid (##\theta=0##) shear and twist free (##\sigma=0, \omega=0)## congruence then we are left with the projected ##R_{ab}## part.
So the rate of change is aways there but does this mean anything if the shear was zero in the first place ?
Yes, I am confused.
Ok, thank you, this makes sense. But like yourself, I am confused about the physics here - I was always under the impression that vanishing Weyl curvature ( i.e. conformal flatness ) implies the conservation of angles, meaning the shape of the ball wouldn't change. There is obviously something going on that I don't know about yet.
I don't think those (global ?) conformal properties affect the local kinematics of a congruence.
But I just worked out the expansion scalar for a basic FLRW (##k=0##) and I get ##\theta=3\ddot{a}/a## and the tidal tensor ##T_{ab}=R_{ambn}\xi^m \xi^n## (##\xi^\mu=\partial_t##) has three equal spatial components ##\ddot{a}/a##. No shape change, even though ##R_{\hat{a}\hat{b}}\ne 0##.
Ok, so in FRW space-time there won't be a shape change. My immediate question then would be - is this true in general whenever the Weyl tensor vanishes ? If not, what attributes does a space-time need to have in addition to a vanishing Weyl tensor to preserve shapes ?
I'm not sure what 'preserving shapes' means globally. Probably it means that if we have a metric ##ds^2=g_{\mu\nu}dx^\mu dx^\nu## the multipling ##g_{ab}## by a constant will preserved angles ( and so 'shapes').
But the behaviour of a ball of particles on a congruence is given by the locally projected quantities ##\sigma_{ab}, \omega_{ab}, \theta## amongst others.
Look for the definitions of those things and you will have the answer.
Yes, that seems like a reasonable definition.
Ok, I will have to take a closer look at these, as I am not really sure what their meaning is, geometrically speaking. It seems like the more you learn about GR, the more you realize all the stuff you don't know yet !
It never ends.:wink:
Section 9.2 of Wald is very good.
But I first learned this stuff from Stephani's little book and he explains that what we are doing is analysing ( decomposing) the part of the acceleration of ##\xi^\mu##, ##\nabla_b \xi_a## that is orthogonal to ##\xi^\mu##. We have brought ourselves to rest wrt the 'flow' and now look at what happens to nearby curves.
That is what those (locally spatially projected tensors) tell us.
Thanks, Mentz114 :smile: I suppose sooner rather than later I should really put that copy of Wald, that has been sitting unread on my shelf for so long, to good use !
