Testing Understanding: Conformally Flat Space-Time
The discussion revolves around the properties of conformally flat space-times, particularly in the context of releasing a ball of test particles and how its shape and volume might change along geodesics. Participants explore the implications of the Weyl and Ricci tensors on the behavior of such a ball in a space-time that is conformally flat but not Ricci flat.
  • Some participants propose that in a conformally flat space-time, a ball of test particles would retain its spherical shape along its geodesic but could either increase or decrease in volume.
  • Others argue that the non-vanishing Ricci tensor implies that the volume of the ball must change, and the shape may not remain spherical, challenging the initial assumption.
  • There is a discussion about the physical significance of the Weyl tensor being trace-free and whether it implies volume preservation.
  • Participants examine the evolution of shear in geodesic congruences and how it relates to the shape of the ball, with some expressing confusion about the implications of non-vanishing shear.
  • Some participants question whether the conservation of angles in conformally flat space-times means that the shape of the ball would not change, leading to further exploration of the conditions required for shape preservation.
  • There is mention of specific calculations in FLRW space-time that suggest no shape change occurs despite a non-zero Ricci tensor.
  • Participants express uncertainty about the generality of shape preservation in conformally flat space-times and what additional attributes might be necessary.
Participants do not reach a consensus; there are competing views regarding whether a ball of test particles retains its shape in conformally flat space-times. Some assert that shape change is inevitable due to the non-zero Ricci tensor, while others suggest that conformal flatness may imply shape preservation under certain conditions.
Participants reference specific mathematical expressions and concepts such as shear, expansion, and the Weyl tensor, indicating a reliance on advanced theoretical frameworks. There is acknowledgment of the complexity of these concepts and the limitations of understanding among some participants.
This discussion may be of interest to those studying general relativity, particularly in understanding the implications of curvature tensors on the dynamics of test particles in various space-times.
Markus Hanke
As an amateur, I am just testing my understanding on the following, since there is nothing worse than harbouring misconceptions.
Suppose we have a space-time ( e.g. of FRW type ) which is conformally flat :
[tex]C{^{\mu \nu }}_{\rho \sigma }=0[/tex]
but not Ricci flat : [tex]R_{\mu \nu }\neq 0[/tex]
Would that physically mean that, if I was to release a ball of test particles in such a space-time, that ball would retain its spherical shape along its geodesic, but either increase or decrease its volume ?
Just wanting to confirm my understanding on this. Thanks in advance !
Also - and I'm not sure if I should open another thread on this - I am aware that the contraction of the Weyl tensor across two of its indices always vanishes ( i.e. it is trace free ). I can see why that would be the case purely algebraically, but I'm not sure about the physical significance of this - does it simply mean that Weyl curvature preserves volume, in a manner of speaking ?
Yes. [Edit: yes to the volume increase/decrease. The shape question is more complicated, see follow-up posts in this thread.]
Yes.
Great, thank you !
No.
If the geodesic congruence has a 4-velocity ##\xi^a## then for vanishing Weyl tensor the shear evolves according to the following: [tex]\xi^c \nabla_c \sigma_{ab} = -\frac{2}{3}\theta \sigma_{ab} - \sigma_{ac}\sigma^{c}{}{}_b - \omega_{ac}\omega^c{}{}_b + \frac{1}{3}h_{ab}(\sigma^2 - \omega^2) + \frac{1}{2}\hat{R}_{ab}[/tex] where ##\theta## is the expansion, ##\omega_{ab}## is the twist, and ##\hat{R}_{ab}## is the spatial projection relative to ##\xi^a## of the trace-free part of the Ricci tensor. Clearly this is non-zero in general, even if we demand that the geodesic ball have vanishing twist. C.f. Wald section 9.2.
WannabeNewton said:
No.
No to the part about retaining spherical shape, correct? If the Ricci tensor is nonzero, then the volume of a small ball of test particles will have to change. In other words, the expansion of a timelike geodesic congruence must be nonzero if the Ricci tensor is nonzero. (More precisely, ##\dot{\theta}## must be nonzero, which means that ##\theta## can't be zero for more than an instant.)
Indeed.
WannabeNewton said:
No.
Ok, I see that my understanding must be off somewhere. Unfortunately I haven't studied Wald ( it's been sitting on my shelf for the past three years or so - it seems like a very "heavy" text for an amateur ), so I am finding it hard to make ( geometric ) sense of the expression above - what physical significance can I attribute to the non-vanishing shear ? In other words, in what way exactly would the shape of the ball change along its geodesic ? How can I visualise that change ? Also, what is [tex]h_{ab}[/tex] in the above expression ?
I appreciate all your help !
Markus Hanke said:
Ok, I see that my understanding must be off somewhere. Unfortunately I haven't studied Wald ( it's been sitting on my shelf for the past three years or so - it seems like a very "heavy" text for an amateur ), so I am finding it hard to make ( geometric ) sense of the expression above - what physical significance can I attribute to the non-vanishing shear ? In other words, in what way exactly would the shape of the ball change along its geodesic ? How can I visualise that change ? Also, what is ##h_{ab}## in the above expression ?
##h_{ab}## is the spatial projection tensor ##g_{ab}+\xi_a \xi_b## where ##\xi^\mu## is a timelike congruence. ( I'm not sure about the sign there).
The expression is the rate of change of the shear tensor ##\sigma_{ab}## projected in the direction ##\xi^\mu##. I have to admit I would like some explanation.
If we have a rigid (##\theta=0##) shear and twist free (##\sigma=0, \omega=0)## congruence then we are left with the projected ##R_{ab}## part.
So the rate of change is aways there but does this mean anything if the shear was zero in the first place ?
Yes, I am confused.
Ok, thank you, this makes sense. But like yourself, I am confused about the physics here - I was always under the impression that vanishing Weyl curvature ( i.e. conformal flatness ) implies the conservation of angles, meaning the shape of the ball wouldn't change. There is obviously something going on that I don't know about yet.
I don't think those (global ?) conformal properties affect the local kinematics of a congruence.
But I just worked out the expansion scalar for a basic FLRW (##k=0##) and I get ##\theta=3\ddot{a}/a## and the tidal tensor ##T_{ab}=R_{ambn}\xi^m \xi^n## (##\xi^\mu=\partial_t##) has three equal spatial components ##\ddot{a}/a##. No shape change, even though ##R_{\hat{a}\hat{b}}\ne 0##.
Ok, so in FRW space-time there won't be a shape change. My immediate question then would be - is this true in general whenever the Weyl tensor vanishes ? If not, what attributes does a space-time need to have in addition to a vanishing Weyl tensor to preserve shapes ?
I'm not sure what 'preserving shapes' means globally. Probably it means that if we have a metric ##ds^2=g_{\mu\nu}dx^\mu dx^\nu## the multipling ##g_{ab}## by a constant will preserved angles ( and so 'shapes').
But the behaviour of a ball of particles on a congruence is given by the locally projected quantities ##\sigma_{ab}, \omega_{ab}, \theta## amongst others.
Look for the definitions of those things and you will have the answer.
Yes, that seems like a reasonable definition.
Ok, I will have to take a closer look at these, as I am not really sure what their meaning is, geometrically speaking. It seems like the more you learn about GR, the more you realize all the stuff you don't know yet !
It never ends.:wink:
Section 9.2 of Wald is very good.
But I first learned this stuff from Stephani's little book and he explains that what we are doing is analysing ( decomposing) the part of the acceleration of ##\xi^\mu##, ##\nabla_b \xi_a## that is orthogonal to ##\xi^\mu##. We have brought ourselves to rest wrt the 'flow' and now look at what happens to nearby curves.
That is what those (locally spatially projected tensors) tell us.
Thanks, Mentz114 :smile: I suppose sooner rather than later I should really put that copy of Wald, that has been sitting unread on my shelf for so long, to good use !
  • · Replies 35 ·
  • · Replies 19 ·
  • · Replies 30 ·
