Asmaa Mohammad
- 182
- 7
Solution for Q1:
Solution for Q2:
Solution for Q3:
Are they correct?
The forum discussion centers on calculating the average electromotive force (emf) in a coil rotating in a magnetic field, specifically addressing the peak emf value of 0.4V. The average emf is derived using the formula -NBA * 4f, where N is the number of turns, B is the magnetic field strength, A is the area of the coil, and f is the frequency. The discussion also clarifies the relationship between the angle θ and the induced emf, emphasizing that θ should be defined based on the coil's orientation relative to the magnetic field. The correct application of the emf equations is crucial for accurate calculations.
PREREQUISITESPhysics students, electrical engineers, and anyone involved in the study of electromagnetic systems and their applications in technology.
Ah, yes, This electronic edition of this exam is different from the one I have, luckily, the peak of the voltage is the only difference, I have just noticed.cnh1995 said:You have taken the peak emf to be 0.04V while the question says it is 0.4V.
As this:cnh1995 said:Also, how did you calculate the average of emf for 1/4 revolution?
The coil starts its motion from the position in which it is parallel to the field lines, I think after 3 seconds it will come back to its original position, where it has a maximum induced emf. But I can't prove this mathematically.cnh1995 said:For Q3: The frequency of emf is 1Hz. After 3 seconds, how many degrees would elapse? What is the emf at the beginning of this 3 second interval?
Right.Asmaa Mohammad said:The coil starts its motion from the position in which it is parallel to the field lines, I think after 3 seconds it will come back to its original position, where it has a maximum induced emf. But I can't prove this mathematically.
Right.Asmaa Mohammad said:The change in the flux dΦ = BA - 0 (BA is the maximum flux linkage when the coil is perpendicular to the field and 0 is flux linkage when the coil is parallel to the field lines) So the change would be (BA - 0).
The change in time dt = T/4 (Where T is period), and since T=1/f -----> dt = 1/4f
The average emf = -N dΦ/dt = -NBA* 4f
It is:cnh1995 said:So what is the general equation of emf in terms of maximum emf and θ, where θ is the angle between normal of the plane and the magnetic field?
Yes. Minus sign is optional.Asmaa Mohammad said:It is:
emf = -NBAω sinθ = (emf)max*sinθ
Isn't it same as above?Asmaa Mohammad said:emf = (emf)max sinθ
I meant it will be like this:cnh1995 said:Isn't it same as above?
No, in this equation we should use pi = 180, and I have already used this equation in solution for Q3, look again!cnh1995 said:So you are confused between when to take pi=180 and pi=3.14?
So, when time passes, (θ = 90 -ωt) in the case we have the problem here,cnh1995 said:At t=0, θ=90°. Therefore θ=90°-ωt and hence, θ=90°-2πft.
This is not correct in your #7. The emf in this case will ve zero.Asmaa Mohammad said:a coil starts its motion from the position it is perpendicular to the field lines, the maximum induced emf in it
You can use θ=90-ωt in #7 as well. At t=0, θ=90°, which is correct since θ is the angle between normal and the magnetic field, which is 90° when the coil is parallel to the field.Asmaa Mohammad said:So, when time passes, (θ = 90 -ωt) in the case we have the problem here,
but for the case in the problem mentioned in #7, it will be like this:
at t=0, θ=0.
Solution for Q2 looks fine, but you should take the peak emf to be 0.4V.
