The biggest value for sin(x)/x
  • Level: Undergrad
  • Thread starter Thread starter Stephanus
    Value
16 replies · 3K views · last reply
Stephanus
Dear PF Forum,
Finally I have written a simple software to plot Sin(X)
It can also draw y = sin(x) + cos(x). But I don't know how to use this function in real life.
This software is very simple.
All you need to do is altering this short function
Code:
    case FDrawMode of
      0: Result:=Sin(X)+Cos(X);
      1: Result:=Sin(X);
      2: Result:=Cos(X);
      3: Result:=Sin(X)/X;
    end;
Don't forget to alter this line also.
Code:
  LS:=edtDrawMode.Items;
  LS.Clear;
  LS.Add('y = Sin(x)+Cos(x)');
  LS.Add('y = Sin(x)');
  LS.Add('y = Cos(x)');
  LS.Add('y = Sin(x)/x');
If you see the last line. LS.Add('y = Sin(x)/x');.
What if X is zero?
I cheat :smile:
Put catch exception in the code.
Code:
      try
        Y:=ScaleY*Fc*                 CalcY(X+Sh); // case of sin(x)/x; if x = 0 then CalcY(X) will cause error.
        YY:=Height1-Round(Y);
        CV.Pixels[XX,YY]:=PlotColor;
      except
        // if error then don't draw anything
      end;
Funnily the computer still draw the curve as it is supposed to be.
And interesting enough. for sin(x)/x the biggest value is 1 for ##\lim_{h \to 0} \frac{\sin(h)}{h}##.
But how to proof that the biggest value for sin(x)/(x) is lim h -> 0?
The graph shows that, but we just can't say. "Well the graph shows that, so the biggest value for sin(x)/(x) is 1",
Anyone interested to proof it?
I think the logical tought is this:
The biggest value for F(x)/x is if x is almost zero.
It makes sense, if x is 4 pi or 8 pi, the value will almost zero, too.
But if x is almost zero then Sin(x) is also almost zero, too.
Hmm, anyone can give a bettter opinon?
The function ##\frac{sin(x)}{x}## is not defined in ##0##. Thus it never becomes ##1##. The function has no biggest value.
Anyway, finding the biggest value (maximum) of a function is a simple exercise with derivatives. Any calculus book should cover this in their section of derivatives.
So the "proof" that ##lim_{h \to 0} \frac{\sin(h)}{h}## is not a "proof"? Thanks, I don't want to argue. Just want to know what other thinks.
"Exercise", I like that.
I don't see how ##\lim_{h\rightarrow 0} \frac{\sin(h)}{h}## is at all relevant here.
Thanks micromass, I don't even see it at the slightest either. It's just an interesting graph, I wouldn't know the answer before the computer shows it. Just want confirmation.
You "just want confirmation" of what?
Your question is very confused. You ask about the "biggest value" of sin(x)/x.
That function does NOT HAVE a largest value. Its value, for any x, is less than 1 but comes arbitrarily close to 1.
Then you talk about the limit as x goes to 0 which is a completely different question! Yes, the limit, as x goes to 0, of sin(x)/x is 1. There are a number of different ways to show that depending on exactly which definition of sin(x) you are using. But that is NOT the value of the function at x= 0 because the function is NOT DEFINED at x= 0.
There is a "removable discontinuity" at x= 0. You could "remove" it by defining f(x)= sin(x)/x if x is not 0, f(0)= 1. But that would be a different function.
Sometimes that is the case, in this case though you know the sin(x) and you know that its periodic however the x increases and reduces the amplitude of the sin(x) so you should expect it to dampen out and approach zero at very large x values. For me the interesting part is where x<1 and the combination of sin(x) / x complements one another to create the curve shown.
You should try other trig functions to see how they act like cos(x)/x or tan(x)/x or (sin(x)+cos(x))/x as well as other functions you learn about and develop a skill to be able to look at a function and sketch how it will look without the computer's help.
Confirmation if I'm right or wrong. First I imagine what is the biggest value for sin(x)/x? I think it might, it might not be x = 0. But one thing for sure.
##\lim_{h \to 0} \frac{\sin(h)}{h}## is 1
And x = pi/2; sin(x)/x is 0. So if we think linearly, it seems from x = 0 to pi/2 the value should decrease right? (or wrong?)
Then I intend to write a computer software, not to find this answer, but because of this:
RUber said:
https://www.physicsforums.com/threads/sine-cosine-limit-summary.827535/
Can you plot the sin and coz functions? Visually, the derivatives and limits are rather easy to see.
Stephanus said:
Tools? Only Microsoft Paint and Microsoft Excel. Of course I could make a small computer program to PutPixel(X,ScreenHeight-Sin(X/100*Pi)*100), but.. that will be tedious.
Then I have time this afternoon, so I wrote a simple program.
Part of the code.
Code:
    case FDrawMode of
      1: Result:=Sin(X);
      2: Result:=Cos(X);
      3: Result:=Sin(X)/X; // ADDED LATER ON
    end;
Then you can see the result as the graph above about sin(x)/x.
"The computer DOES NOT show error if x=0??" Don't worry I cheat :smile:, see my post above.
Okay, so I see the graph, it seems that if x close to zero sin(x)/x is the highest.
But you know about computer variable. I use a very rough calculation, loop by 0.0001*pi step. And 0.0001 is very rough for math but not for computer variable.
So there remains some question.
1. Isn't there along the line from x = 0 to pi/2 a spike where sin(x)/x is bigger than 1?
2. Sin(x)/x looks (yes, "looks", because it's shown on the screen) highest at x = 0, but x can't be zero, right?
3. Is this true that the biggest value for sin(x)/x is ##\lim_{x \to 0} \frac{\sin(x)}{x}##
But:
Okay, so I'm satisfied enogh with micromass answer.
Yes, micromass has answered it.
Yes.
Code:
double SinXPerX1(double arc)
  return(Sin(arc)/arc);
double SinXPerX2(double arc)
  if(arc==0) return(1); else return(Sin(arc)/arc);
Agreed, it's different functions.
No.
Right.
No.
micromass said:
"1. Isn't there along the line from x = 0 to pi/2 a spike where sin(x)/x is bigger than 1?" No
"2. Sin(x)/x looks (yes, "looks", because it's shown on the screen) highest at x = 0, but x can't be zero, right?" Right
"3. Is this true that the biggest value for sin(x)/x is ##\lim_{x \to 0} \frac{\sin(x)}{x}##"No
Come on micromass. I didn't ask that. I'm afraid I have already asked too many questions a day. But that WAS my doubt, and I'm already satisfied with this:
But, thank you very much for your answer. It removes my doubts. I'm afraid I have asked too many questions.
It seems Cos(x)/x similar to (Sin(x)+Cos(x))/x
Ahhh, I already
Code:
    case FDrawMode of
      1: Result:=Sin(X);
      2: Result:=Cos(X);
      4: Result:=Cos(X)/X; // added
      5: Result:=Sin(X)/Cos(X)/X; // has to change tan to sin/cos, no Tan function in Delphi
      6: Result:=(Sin(x)+Cos(x))/x
    end;
Alter it, compile it, run it, save the graph and upload it.
Hmm.., I didn't think that tan(x)/x will look like that. Picture it without computer or paper? Well, I'm not Descartes, but I'll try.
IMO, the most important point here is the difference between a function's value (which might not exist) at a particular point and the limit of a function at that point. Two of your graphs are significant here: the graphs of ##y = \frac{sin(x)}{x}## and ##y = \frac{tan(x)}{x}##.
Both graphs appear to show a point at (0, 1). In fact, neither function is defined when x = 0. The graphing software (the program you wrote in Delphi) plots a number of points and then connects the dots.
Even though both functions are undefined at x = 0, both functions have limits that exist as x approaches 0. In mathematical notation ##\lim_{x \to 0}\frac{sin(x)}{x} = 1## and ##\lim_{x \to 0}\frac{tan(x)}{x} = 1##. It's very easy to show that the latter limit can be gotten once you know the first limit.
##\lim_{x \to 0}\frac{tan(x)}{x} = \lim_{x \to 0}\frac{sin(x)}{cos(x) \cdot x} = \lim_{x \to 0}\frac{1}{cos(x)} \cdot \lim_{x \to 0}\frac{sin(x)}{x}##.
The first limit is clearly 1, since cos(0) = 1, and we know that the second limit is 1.
Hi Mark44, it's been a while since you answer my post in: https://www.physicsforums.com/threads/proof-limit-derivatave-of-sin-x.826864/page-3#post-5198643
Thanks a lot! A good point! Function value which might not exist vs the limit of that function in that point.
Yes both are undefined at x = 0.
Just plot the dots not connect it.
I put something like it in the software.
Code:
try // begin catch error
  Y = sin(x)/X; // calculate Y
  PuPixel(X,Y); // Draw the result
except
  // catch any error
  // don't do anything
end;
The original code is at my first post above.
Yes, yes I know. You've given me this lecture since 2 weeks ago. Thanks :smile:
Proof why tan(x)/x = 1? Perhaps later. For now, I'm already satisfied that I can proof why ##\lim_{h \to 0} \frac{\sin(h)}{h} = 1##
Ahh, that's the proof? Very simple actually.
