The electric field due to a point charge
The discussion focuses on solving a physics problem related to the electric field due to a point charge, specifically problem 22.8 from a referenced PDF. Participants clarify the mathematical setup involving the electric fields from two charges, expressed as E=((k)(Q))/r^2. The quadratic equation derived from the problem is 5x^2 - 10xL + 5L^2 = 2r^2, which can be solved using the quadratic formula to yield (1/3)(L)(5 + √10). The conversation emphasizes understanding the relationships between the variables involved, particularly the distances to each charge.
  • Understanding of electric fields from point charges
  • Familiarity with quadratic equations and the quadratic formula
  • Knowledge of constants such as Coulomb's constant (k) and permittivity of free space (ε₀)
  • Basic algebraic manipulation skills
  • Study the derivation of electric fields from multiple point charges
  • Learn how to apply the quadratic formula to solve equations with two variables
  • Explore the implications of electric field strength in different configurations of point charges
  • Investigate the concept of superposition in electric fields
Students of physics, educators teaching electromagnetism, and anyone interested in understanding electric fields and their mathematical representations.
Jay9313
http://www.monmsci.net/~fasano/phys2/Chap22_10.pdf
The question is on this PDF File. It's 22.8. I get the logic of it, the electric fields will be 0 only when they both have the same magnitude. The math is shown below the problem, but i don't understand it. Could someone solve this and show me how to do this step by step?
(You can see I'm not cheating, because if I was, I would just copy the answer out of that page. I want to understand it and do well in this class.)
The way things work here is that you give it a shot and we provide hints and help.
Are you familiar with the field from a single point charge?
Yeah, It's E=((k)(Q))/r^2
Welcome to PF!
Hi Jay9313! Welcome to PF! :smile:
Which bit do you not understand?
Do you understand (ignoring the constants) 5q/x2 = 2q/(L-x)2 ?
The way I was setting this problem up is
(2)/((4 Pi Episilon zero)(x^2)) = (5)/((4 Pi Epsilon zero)(x+L)^2)
Then I would solve, and I used the quadratic formula. I got
(-10 +_ 6.3L)/6
I have no clue how to solve for L, and I don't even know if my math is right
Good.
So, at point (x,0), how would you express the field from each charge? What's the distance to each in terms of the givens?
I ignored the constants, that was easy. I got to the point where I got a quadratic. 3x^2 + 10xL + 5L^2
Is the quadratic right? How do you solve for a quadratic with two variables? =(
Doc Al said:
Good.
Well the fields would be equal to each other. The distance would be (x+L)^2 right?
What two variables? L is a constant. You'll express your answer in terms of L.
I got (-10L +_ 6.3L)/6 = 0
How would you solve that? Can you even solve it?
x is the distance from the point to the origin, where q1 is. So what's the distance to q1?
L is the distance between the charges, so what's the distance to q2?
Oh! Is is L and x + L?
Not quite. The distance to q1 is x. Is the distance to q2 shorter or longer?
Oh ok, it's x and x + L , but since it is a function that is squared, it would have to be x-L. So you get (5)/((4 Pi Epsilon zero)(X^2) and you get (2)/(( 4 Pi Epsilon zero)(X-L)^2) right? =D
Then once you cancel terms, you get
5x^2-10xL+5L^2= 2r^2
You then solve the above equation using the quadratic formula, and you get
(10L+2LSqrt(10))/6
The above equation can be simplified by first reducing the 6..
(5L+LSqrt(10))/3)
You can then pull that 3 out to make it look nicer.
(1/3)(5L+LSqrt(10))
Then you can factor out an L
(1/3)(L)(5+Sqrt(10))
And it's not plus or minus Sqrt(10) because it's length, and you can't have a negative length. Am I right? =D
Thank you so much =D I sat down for lunch, and I was waiting for the food, and I was just thinking about it non stop. Then it slowly started to fit together. =D
  • · Replies 68 ·
