The force of wind blowing on a wall at an angle
The discussion centers on calculating the force exerted by wind on a wall at a 45-degree angle. The initial calculation proposed that the force is 1.2√2v²wh Newtons, based on the momentum change of air particles colliding elastically with the wall. However, it was identified that the mass of air impacting the wall should be adjusted to 1.2vwhsin(45°), leading to a corrected force calculation of 1.2v²wh Newtons. This adjustment accounts for the angle of incidence of the wind on the wall.
  • Understanding of momentum and its relation to force (Δp = FΔt).
  • Knowledge of basic physics principles regarding elastic collisions.
  • Familiarity with vector components and trigonometric functions, specifically sin(45°).
  • Concept of air density and its impact on mass calculations (1.2 kg/m³).
  • Study the principles of fluid dynamics, focusing on wind forces on structures.
  • Learn about vector decomposition and its applications in physics problems.
  • Explore advanced topics in momentum conservation in elastic collisions.
  • Investigate real-world applications of wind load calculations in engineering.
Students in physics, engineers involved in structural design, and anyone interested in the effects of wind on buildings and structures.
hyperddude
Say there is a wall with width w meters and height h meters. There is a wind with velocity v m/s blowing on the wall at a 45 degree angle. The collisions of the air molecules with the wall are perfectly elastic. What is the magnitude of the force on the wall? (The density of air is 1.2 kg/m^3).
Δp = FΔt (p is momentum)
In one second, an air particle moves v meters. The area of the wall is wh, so the volume of the air that hits a surface in one second is vwh. The density is 1.2kg/m^3, so the mass would be 1.2*vwh. My next step would be to find the change in velocity, which I think is v\sin{45°} + v\sin{45°} = \sqrt{2}v.
So, the change in momentum would be mv = 1.2\sqrt{2}v^2wh. The time is 1 second, so the force would be 1.2\sqrt{2}v^2wh Newtons. Is my method correct?
I think you are overestimating the mass of the air hitting the wall. If the wall were directly facing the wind the volume would be vwh. But it's tilted away from the wind, shouldn't it be less? And I think your answer for the change in velocity came out ok, but you should really be doing it by taking the difference of two vectors.
Oh, good catch. I believe the mass should be 1.2*vwh\sin{45°}. So the force is 1.2v^2wh?
I think so.
Thanks!
  • · Replies 39 ·
  • · Replies 26 ·
  • · Replies 23 ·
