Undergrad Geodesic in Weak Field Limit: Introducing Einstein's Relativity
The discussion revolves around the derivation of the geodesic equation in the weak field limit as presented in "Introducing Einstein's Relativity." Participants are clarifying the transition from the equation involving proper time to the geodesic equation, specifically the term "(1 + O(ε))". There is confusion regarding the Taylor series expansion and its implications for the terms involved, particularly how certain derivatives relate to the order of ε. The importance of correctly following the authors' instructions and showing work is emphasized to facilitate understanding. The conversation highlights the complexity of the derivation and the need for clearer explanations in the text.
GR191511
I'm reading《Introducing Einstein's Relativity_ A Deeper Understanding Ed 2》on page 180,it says:
since we are interested in the Newtonian limit,we restrict our attention to the spatial part of the geodesic equation,i.e.when a=##\alpha####\quad ##,and we obtain,by using ##\frac{d\tau}{dt}=1+O(\varepsilon^2)##:
##\frac {\partial^2 x^\alpha} {\partial t^2}+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}(1+O(\varepsilon))=0##.##\quad ##I wonder how the auther gets "(1+O(##\varepsilon##))"?
The authors (D'Inverno & Vickers) explained that on p179, just before eq(10.43). Do you not understand how eq(10.43) was obtained? Their preceding (unnumbered) equation is $$c^2 d\tau^2 ~=~ c^2 dt^2 (1 - \varepsilon^2) ~.$$ Take the square root of both sides. You might have to expand ##\sqrt{1 - \varepsilon^2}## as a Taylor series in ##\varepsilon## to see why it ends up as ##\,1 - O(\varepsilon^2)##.
Likes PeroK, topsquark and vanhees71
Thanks!But it doesn't end up as"##1+O(\varepsilon^2)##",it is"##1+O(\varepsilon)##"
Check your work. Doing a Taylor series expansion of ##\sqrt{1 + \varepsilon^2}## does not mean you take the square root of ##\varepsilon^2##.
Likes topsquark and Vanadium 50
I mean the geodesic "##\frac {\partial^2 x^\alpha} {\partial t^2}+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}(1+O(\varepsilon))=0## "it ends up as ##(1+O(\varepsilon))##
You make it much harder to help you if you don't show your work. I'm guessing you haven't correctly followed the author's instructions after eq(10.46).
Likes topsquark and vanhees71
##\frac {d^2 x^\alpha} {d \tau^2}+\Gamma^\alpha{}_{bc}\frac{dx^b}{d\tau}\frac{dx^c}{d\tau}=0\Rightarrow\frac{d}{d\tau}(\frac{dx^\alpha}{dt}\frac{dt}{d\tau})+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}\frac{dt}{d\tau}\frac{dt}{d\tau}=0\Rightarrow##
##\left[\frac{d}{dt}(\frac{dx^\alpha}{dt}\frac{dt}{d\tau})\right]\frac{dt}{d\tau}+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}\frac{dt}{d\tau}\frac{dt}{d\tau}=0\Rightarrow\frac{d}{dt}(\frac{dx^\alpha}{dt}\frac{dt}{d\tau})+####\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}\frac{dt}{d\tau}=0\Rightarrow\frac{d^2x^\alpha}{dt^2}\frac{dt}{d\tau}+\frac{dx^\alpha}{dt}\frac{d}{dt}(\frac{dt}{d\tau})####+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}\frac{dt}{d\tau}=0####\Rightarrow\frac{d^2x^\alpha}{dt^2}\frac{dt}{d\tau}+0+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}\frac{dt}{d\tau}=0\Rightarrow\frac{d^2x^\alpha}{dt^2}+\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}####=0####\Rightarrow\frac{1}{c^2}\frac{d^2x^\alpha}{dt^2}+\frac{1}{c^2}\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}=0####\quad##So where is the ##1+O(\varepsilon)##?
Likes Dale
OK, it's actually a lot simpler than what you've written in post #7.
From (10.43) we have ##d\tau = dt + O(\varepsilon^2)##. That means you can replace all the ##d\tau##'s in the derivatives by ##dt##. (Think of those derivatives as ratios of differentials.)
The trick they don't seem to explain is that ##d^2 x^\alpha/dt^2## is ##O(\varepsilon)##, as is ##\Gamma^a_{~bc}##, which is shown in (10.45) as an ##\varepsilon## term plus ##O(\varepsilon^2)##. In the geodesic equation after (10.46), they divided throughout by 1 factor of ##\varepsilon##.
(Is that explanation sufficient? I'll agree they probably could have been clearer.)
Likes Dale and vanhees71
Why is "##d^2 x^\alpha/dt^2## is ##O(\varepsilon)##"related with this question?
Do you mean it is ##\frac{\varepsilon}{c^2}\frac{d^2x^\alpha}{dt^2}+\frac{\varepsilon}{c^2}\Gamma^\alpha{}_{bc}\frac{dx^b}{dt}\frac{dx^c}{dt}(1+O(\varepsilon))=0##before" they divided throughout by 1 factor of ##\varepsilon##"?Thank you!
That's the general idea. But... (sigh)... now you've got me wanting to rewrite that stuff properly without skipping steps. Probably not today though.
Likes GR191511
  • · Replies 28 ·
  • · Replies 35 ·
