The Hamiltonian and Galilean transformations
The discussion revolves around the Hamiltonian formulation of mechanics, particularly in the context of Galilean transformations. Participants explore the implications of changing reference frames on the Hamiltonian and the relationship between kinetic and potential energy in different inertial frames. The conversation includes technical derivations and clarifications regarding the definitions of variables involved.
  • One participant presents a Hamiltonian that includes a term in U when using a coordinate q, leading to confusion about the significance of U in a static frame of reference.
  • Another participant questions the definitions of momentum variables p and P, suggesting different forms of kinetic and potential energy.
  • A participant derives the Hamiltonian in terms of P and Q, noting that ignoring U leads to a different formulation of the Hamiltonian without U, raising questions about the physical significance of the Hamiltonian.
  • One participant provides an alternative Hamiltonian formulation with a different signature, highlighting the presence of the Up term and its implications for equations of motion.
  • Discussion includes the necessity of canonical transformations in Hamiltonian formalism to maintain form invariance under Galilean transformations.
  • Another participant expresses confusion about the implications of changing coordinates and the role of U in the Lagrangian, suggesting that U should not appear in the transformed Lagrangian.
  • Clarifications are made regarding the differences between Lagrangian and Hamiltonian formalisms, particularly in relation to invariance under transformations.
  • Participants explore the use of generating functions to achieve desired transformations in the Hamiltonian framework, aiming to eliminate U from the final Hamiltonian expression.
Participants express differing views on the role of U in the Hamiltonian and whether the Hamiltonian is invariant under Galilean transformations. There is no consensus on the implications of these transformations for the physical significance of the Hamiltonian.
Participants note the importance of canonical transformations for maintaining the form of the Hamiltonian under changes of reference frames. There are unresolved questions regarding the definitions of momentum and the implications of different formulations of the Hamiltonian.
epovo
TL;DR
The effect of a coordinate transformation on the Hamiltonian is surprising (for me!)
In a classical example, for a system consisting of a mass attached to a spring mounted on a massless carriage which moves with uniform velocity U, as in the image below, the Hamiltonian, using coordinate q, has two terms with U in it.
But if we use coordinate Q, ##Q=q−Ut##, which moves with the carriage, the Hamiltonian, to my surprise, still contains a term in U.
$$ H=\frac 1 2 p^2/m+Up+\frac 1 2 kQ^2 $$
By choosing coordinate Q I assumed we have moved to a static frame of reference in which U can be ignored. But that does not seem to be the case.
I could calculate the Hamiltonian as if the carriage was static, and I would of course get
$$ H=\frac 1 2 P^2/m+\frac 1 2 kQ^2 $$
I am confused.
What are definitions of p and P ? I see
[tex]PE=\frac{1}{2}kQ^2[/tex]
[tex]KE=\frac{m}{2}(U+\dot{Q})^2[/tex]
ok,
$$ L = \frac{m}{2}(U+\dot{Q})^2 - \frac{1}{2}kQ^2$$
$$ p = m\dot{Q} + mU $$
$$ H = \dot Q p - L = ...= \frac 1 2 p^2/m+U p+\frac 1 2 kQ^2 $$
If we ignore U completely, Kinetic Energy is simply ## KE = \frac{m}{2}\dot{Q}^2 ##. Therefore
$$ P = \frac {\partial L} { \dot Q} = m \dot Q $$
and
$$H=\frac 1 2 P^2/m+\frac 1 2 kQ^2$$
My confusion is that the first formulation of H contains a term in U and the second one, which should be equivalent, does not. Which leads me to think of the Hamiltonian as little more than a mathematical device with no physical significance.
Either formulation leads to the same, and correct, equations of motion.
Thanks for details. I got one of a diferent signature
[tex]H=\frac{p^2}{2m}-Up+\frac{k}{2}Q^2[/tex]
which gives a equation
[tex]\frac{\partial H}{\partial p}=\frac{p}{m}-U=\dot{Q}[/tex]
-Up term seems all right.
The first one and the second one belong to different inertial frame of references, IFRs. Hamiltonian is not invariant under Galilean transformations.
Note that you have to do a canonical transformation in the Hamiltonian formalism in order to have form invariance. So let's write everything a bit more careful.
You start with phase-space coordinates ##(Q,P)##. The Lagrangian reads
$$L=\frac{m}{2} (\dot{Q}+U)^2-\frac{k}{2} Q^2.$$
The canonical momentum is
$$P=\frac{\partial L}{\partial \dot{Q}}=m(\dot{Q}+U).$$
The Hamiltonian reads
$$H'(Q,P,t)=P \dot{Q}-L=m (\dot{Q}^2+U \dot{Q})-\frac{m}{2} (\dot{Q}^2+2 \dot{Q} U +U^2)+\frac{k}{2} Q^2=
\frac{m}{2} \dot{Q}^2 -\frac{m}{2} U^2 + \frac{k}{2} Q^2.$$
Now we have eliminate ##\dot{Q}## in favor of ##P##:
$$H'=\frac{m}{2} (P/m-U)^2-\frac{m}{2}U^2 + \frac{k}{2} Q^2 = \frac{1}{2m} P^2 - P U + \frac{k}{2} Q^2.$$
Now you want to change to new canonical coordinates ##(q,p)## with ##q=Q+U t##. So we have to find the corresponding canonical transformation. The most simple way is to find a generating function ##g=g(q,P,t)##. Then
$$Q=\frac{\partial g}{\partial P}, \quad p=\frac{\partial g}{\partial q}, \quad H=H'-\frac{\partial g}{\partial t}.$$
Obviously
$$g=P(q-Ut)$$
does the job, and you get
$$H=\frac{p^2}{2m} +\frac{k}{2}(q-Ut)^2,$$
which is also what you directly get from starting with the Lagrangian
$$L=\frac{m}{2} \dot{q}^2-\frac{k}{2}(q-Ut)^2.$$
I didn't know about canonical transformations. But I thought that by making the coordinate transformation ##Q=q-Ut##, I had changed my frame of reference, so that U loses its meaning and should not be part of the Lagrangian at all.
When you work in the Hamiltonian formulation, you must use a canonical transformation to keep the formalism form-invariant (general symplectomorphism invariance of phase space). In the Lagrangian formalism you can do arbitrary transformations of the generalized coordinates (general diffeomorphism invariance of configuration space).
In the Lagrange formalism you have
$$L=\frac{m}{2} (\dot{Q}+U)^2 + \frac{k}{2} Q^2 = \frac{m}{2} \dot{Q}^2 + \frac{k}{2} Q^2 + m \dot{Q} U +\frac{m}{2} U^2=\underbrace{\frac{m}{2} \dot{Q}^2 + \frac{k}{2} Q^2}_{L'} +\frac{\mathrm{d}}{\mathrm{d} t} \left (m QU + \frac{m}{2} U^2 t \right).$$
The Lagrangian ##L'## is thus equivalent to the Lagrangian ##L##, and ##L'## is indeed independent of ##U## as it's clear from Galilei invariance.
Thank you very much @vanhees71 : That gives me peace of mind. It will probably be covered later in the text I am following, but when I saw this example I was troubled :)
You can also get this within the Hamiltonian formalism. Starting again from
$$H'=\frac{1}{2m} (P-mU)^2 -\frac{1}{2m} ^2 + \frac{k}{2} Q^2,$$
we look for a canonical transformation which leads to ##p=P-mU## and ##q=Q## and such as to make ##H(q,p)## independent of ##U##.
We use again the generating function of the type ##g(q,P,t)##. Then we have
$$Q=\frac{\partial g}{P} \stackrel{!}{=}q \; \Rightarrow \; g(q,P,t)=q P + g_2(q,t).$$
Nowe we want
$$p=\frac{\partial g}{\partial q} \stackrel{!}{=}P-mU=P+\frac{\partial g_2}{\partial q} \; \Rightarrow \; g_2(q,t)=-m U q + g_3(t).$$
Then you get
$$H=H'-\frac{\partial g}{\partial t}=\frac{1}{2m} p^2 -\frac{1}{2m} U^2 + \frac{k}{2} q^2 -\dot{g}_3.$$
So setting
$$g_3(t)=-\frac{1}{2m} U^2 t$$
we finally get
$$H=\frac{1}{2m} p^2 + \frac{k}{2} q^2.$$
  • · Replies 59 ·
