The James Webb Space Telescope
546 replies · 80K views · last reply
Vanadium 50 said:
Uranus is pretty featureless. The rings seem to come out better, but that doesn;t surprise me in the IR.
Well I have never seen Uranus looking like that, the rings give it a different personality.
Set to music in a video I agree was probably not the best way to illustrate it.
A recent clip on CBS 60 Minutes about the new images from JWST:
NASA's James Webb Space Telescope: Stunning new images captured of the universe | 60 Minutes
(April 10, 2023)
"As NASA’s Webb telescope scours the universe to find light from the first stars and galaxies, it is also capturing the universe like never before. Scott Pelley got an inside look at Webb’s new discoveries."
  • Love
At 2:30, he states that the galaxy they are looking at is more than 33 billion ly away??? Am I missing something? Last I remember, the universe is only 13 billion years old.
Yes, but the observable universe has about a 45bn light years radius at present. The growth rate is not limited by ##c##.
Ah. I had never heard of anything being observed beyond 13 billion ly.
Image from Webb of a galaxy merger. All the galaxies in the back ground too
https://www.nasa.gov/feature/goddard/2023/webb-captures-the-spectacular-galactic-merger-arp-220
Webb telescope image of the merging galaxy Arp 220: a bright glowing central core with blue-tinted and orange-brown dusty streaks radiating outward, surrounded by faint background galaxies on a black field.
  • Wow
pinball1970 said:
The six spike diffraction thing? @Andy Resnick @collinsmark with Webb?
Isn't that spike diffraction the standard thing with Webb, i.e. the same type of spikes that appear in photos of bright stars by Webb?
I don't know exactly why they appear (I guess it's either some "thingy" in front of the detector or maybe something due to the hexagonal mirrors, perhaps? (just a guess)). I remember seeing a video where they mentioned the spikes, but I don't think they specified in the video why the spikes appear.
It's a diffraction effect from the mirror, with six-fold symmetry because of the hexagonal structure.
If you look at (e.g.) this Astronomy Picture Of The Day from Hubble you can see cross shaped rays from the bright stars.
Hubble image of two interacting spiral galaxies against a dark starry background, one large face-on spiral with a bright orange core and a smaller elongated companion to its lower right.
Source
That's a diffraction effect from the + shaped "spider" that supports the secondary mirror. Webb's spikes are more impressive, I would guess because it's a hexagonal mirror rather than a basically round mirror with a relatively minor four-fold symmetric obstruction.
  • Wow
"Distance" in our expanding universe makes only sense if we mean distance at a fixed time, e.g. the distance between us and a galaxy far away at the time of emission or absorption of it's light.
It's the first big one I have seen since that initial calibration image. The star image with all the galaxies in the background that got all the astronomy community very excited.
The six diffraction spikes are more caused by the three supports that support the secondary mirror. As said above, the Hubble has four secondary supports, so you get four diffraction spikes. The three Webb supports lead to six diffraction spikes, because you get one opposite to the support as well. I think the segmented mirrors also contribute to the diffraction spikes, but I think the secondary supports are the main cause.
Every detailed description I have seen says that the hexagonal mirrors are the larger contributor and if you just ballpark it there are more hexagon edges than support edges. Also there are not six spikes, it has eight. The fainter horizontal one is caused by the vertical support. The other two supports line up with the non horizontal hexagon edges.
Fun fact if you run the FFT algorithm on the NIR selfie image you get the spike pattern as a result.
Two-panel Fourier transform demonstration: left, a logarithmic-scale Fourier transform modulus showing bright diffraction spikes radiating from the centre; right, the inverse transform reconstructing a segmented hexagonal aperture mask with three dark support strips.Telescope image of a bright star with diffraction spikes in red and orange, against a dark field with scattered faint galaxies.
That isn't quite right.
If a telescope's secondary mirror was attached with a single rod/pole holding there would still be two diffraction spikes; each spike being perpendicular to the direction of the pole/rod/support.
In other words, consider a vertical pole that extends from the bottom of view to the center, where it holds the secondary mirror, the result would be two horizontal diffraction spikes: one in each direction. Now you can add another support, going from top to the center, without increasing the number of diffraction spikes, since the diffraction spikes from the two supports simply overlap.
The bulk of the diffraction spikes on the James Webb Space Telescope (JWST) come from the hexagonal pattern of the mirrors. Each mirror has 6 sides, and each side produces two diffraction spikes, one in each perpendicular direction. So there are really 12 spikes, but due to the symmetry of a hexagon there's overlap, so the end result is 6 observed spikes caused by the hexagonal shape.
Now we consider the 3 rods from the spider vanes holding the secondary in place. Two of those rods are aligned with the sides of hexagonal shape of mirror, so no new diffraction spikes are created by these rods (since they overlap with other spikes). That leaves the third rod that is not in line with any of the sides of the hexagonal shape of the mirrors. This rod leaves a new set of diffraction spikes -- and those additional two spikes are perpendicular to the rod.
So in the end, there's 8 diffraction spikes on JWST's optics: 6 prominent ones and 2 minor ones in the diffraction pattern.
[Edit: Technically, of the 8 diffraction spikes, there's 4 really prominent ones caused by both the hexagonal mirrors plus two of the secondary support rods, 2 somewhat prominent ones caused by the hexagonal mirrors without any secondary mirror support diffraction, and finally 2 subtle spikes caused by one of the support rods.]
It's worthwhile to note that this this diffraction pattern (which is wavelength dependent; I haven't discussed that here) doesn't just affect the resultant appearances of bright stars, but also the dim stuff too. Every light ray, every pixel in the image is affected by the convolution of the diffraction pattern across the entire image. Sure, the pattern is only obvious to bright stars due their higher contrast, but the diffraction pattern actually affects everything.
Edit: Conceptually, this is like trying to paint a picture on a canvas with the limitation that your brush is the shape of the diffraction pattern. It's not possible to place a dot on the canvas smaller than the brush/diffraction pattern; it's all or nothing. You can change the brightness, but not the size (for a given color). Also different colors will have slightly different sized brushes, thus slightly different sized diffraction patterns.
This makes a lot of sense, and is much more correct than what I wrote. Thanks for the detailed explanation.
Two-panel visualisation: left, a grayscale logarithmic Fourier transform modulus showing a bright centre with six diagonal spikes and horizontal and vertical streaks; right, the inverse transform showing a hexagonal segmented aperture with a central obstruction and three support struts.
https://www.physicsforums.com/attachments/fft-jpg.325333/
The vertical support causes the 2 horizontal spikes and the edges of each mirror segment and the other 2 supports cause the other 6 spikes, so there’s a actually 8 spikes but the 6 spikes from the mirror edges and slanted supports are more prominent.
If you look closely at the 2 horizontal spikes, wave interference effects are prominent (the dark areas within each horizontal spike.) Thats from the light taking 2 different length paths to the image sensor from diffraction on either side of the vertical support causing destructive wave interference at some locations.
I was surprised to find out with such a big mirror the f ratio on the Webb is f/20.2. F ratio tells you how bright a point source will be on the sensor pixel at a given exposure time, with smaller numbers being brighter and generally “better” and more expensive, usually meaning a wider lens with more glass for the same field of view. A very nice camera lens is usually f/1.4 or f/2.8. Very expensive telescopes are usually f/4 to f/8 range. I have a sub $1000 (cheap) 2000mm focal length Maksutov Cassegrain reflector telescope and it’s roughly f/14.5… the James Webb is f/20.2! That means despite its huge mirror, a given point source will be much dimmer on a given pixel than an ordinary camera or telescope for the same exposure time. Interesting.
To expand somewhat on what @timmdeeg said in post #432:
The universe IS only 13+billion years old, but it has been expanding all that time and the expansion is accelerating. SO ... something that we see, that released its light, say, 6 billion years ago is NOT 6 billion light years away. During the 6 billion years that it took for that light to reach us, the object that emitted it has moved MUCH father away.
The objects at the edge of the observable universe are receeding from us at about 3c and although we see their light as being 13 billion years old, the objects are now at something like 47 billion light years away from us.
To Illustrate:
50mm focal f/1.4:
Photo of a black camera lens with its front element facing up, a dust-speckled rim, and a lens cap with a clip lying beside it on a dark reflective surface.
50mm focal f/16:
Photo of a camera lens viewed from the front, showing the aperture blades and a small dark central spot, with coloured light flecks inside and dust on the glass.
Large telescopes for digital imaging use often have very large focal length (and high focal ratios). They compensate by having very large imaging chips with large pixels. Focal ratio is not very useful for them and is seldom used, etendue is the performance metric of choice among the professionals.
The Vera C Rubin Observatory will be f/1.2. Keck is f/1.75. Hubble f/24. Giant Magellan Telescope will be f/8.
Scale comparison chart of optical and radio telescopes and space telescopes, drawn as circles and hexagonal mirror layouts at the same scale, with human, tennis court and basketball court references.
Some of those things make Webb look small!
Webb Looks for Fomalhaut’s Asteroid Belt and Finds Much More (NASA, May 8, 2023)
NASA article: here
Nature paper: here
Science News article: here
Infrared image of the dusty debris disk around the star Fomalhaut, seen tilted, showing nested rings of glowing orange dust around a bright central star blocked by a black mask.
"This image of the dusty debris disk surrounding the young star Fomalhaut is from Webb’s Mid-Infrared Instrument (MIRI). It reveals three nested belts extending out to 14 billion miles (23 billion kilometers) from the star. The inner belts – which had never been seen before – were revealed by Webb for the first time.
Credits: NASA, ESA, CSA, A. Gáspár (University of Arizona). Image processing: A. Pagan (STScI)"
  • Love
"etendue" That one I had to look up:
Short version:
https://en.wiktionary.org/wiki/etendue
Long version:
https://www.optica.org/en-us/events/webinar/2019/what_is_etendue_and_why_is_it_important/
NASA article: here
Nature paper: here
DennisN looks at Fomalhaut's Center and Finds Much More (PF, May 12, 2023)
False-colour image of a tilted orange-yellow dusty debris disk around a bright central star, with a small black spot at the centre and a green box with text reading I let advanced AI software analyze this blob...
Inclined glowing orange-yellow disk of dust around a bright central star, with a small dark grey blob at the centre and the caption "Hmm... is there a shape in the center? Let's magnify..." below.
Meme: a dark, irregular polygonal shape sits over a glowing golden-orange disk of dust, with the caption "Strange... it looks somewhat familiar..."
Dark, irregular rock-like object floating against a glowing orange background, with a caption reading: Oh no! Resistance is futile... we are doomed!
Sorry, I could not resist :smile:.
  • Glowing orange-yellow disk of dust around a bright central star, with a dark irregular fragment pasted over its center and the caption "Strange... it looks somewhat familiar..." below.
  • Haha
