eboy32
- 3
Could someone explain what this crazy new discovery means? Is it the rosetta stone of QM?
eboy32 said:When will we realize that QM is alien intelligence looking at us right in the face.
Zarqon said:There's one thing I don't really get from that article. They keep stating that "locality is a central pillar" in quantum field theory. But what could they possibly mean by that, considering the fact that quantum entanglement (which QFT should be consistent with) is well described by the opposite: non-locality.
Zarqon said:So just to get what you said, you mean that in QFT locality instead means: An event somewhere in space cannot be caused by something outside the light cone?
Wolchover said:The amplituhedron, or a similar geometric object, could help by removing two deeply rooted principles of physics: locality and unitarity.
Locality is the notion that particles can interact only from adjoining positions in space and time. And unitarity holds that the probabilities of all possible outcomes of a quantum mechanical interaction must add up to one. The concepts are the central pillars of quantum field theory in its original form, but in certain situations involving gravity, both break down, suggesting neither is a fundamental aspect of nature.
Encoded in its volume are the most basic features of reality that can be calculated, “scattering amplitudes,†which represent the likelihood that a certain set of particles will turn into certain other particles upon colliding.
Wolchover said:Locality says that particles interact at points in space-time. But suppose you want to inspect space-time very closely. Probing smaller and smaller distance scales requires ever higher energies, but at a certain scale, called the Planck length, the picture gets blurry: So much energy must be concentrated into such a small region that the energy collapses the region into a black hole, making it impossible to inspect. “There’s no way of measuring space and time separations once they are smaller than the Planck length,†said Arkani-Hamed. “So we imagine space-time is a continuous thing, but because it’s impossible to talk sharply about that thing, then that suggests it must not be fundamental — it must be emergent.â€
Obviously the informal definitions highlighted above may be of use to Zarqon, others here:Wolchover said:Unitarity says the quantum mechanical probabilities of all possible outcomes of a particle interaction must sum to one. To prove it, one would have to observe the same interaction over and over and count the frequencies of the different outcomes. Doing this to perfect accuracy would require an infinite number of observations using an infinitely large measuring apparatus, but the latter would again cause gravitational collapse into a black hole. In finite regions of the universe, unitarity can therefore only be approximately known.
So for some questions of my own: Am I right to think that the disposal of 'locality' proffered in the article is closely related to the Holographic Principles/proposals associated with quantum gravity? I gathered that from language like in the quotations provided--especially the parts about black holes & horizons, and Planck scales. Is this new treatment of 'locality' invoked to avoid the problems (that I've often heard reference to) associated with continuous spacetime and those 'notorious' quantum infinites?? (Hope I'm on the right path here, at least!Zarqon said:So just to get what you said, you mean that in QFT locality instead means: An event somewhere in space cannot be caused by something outside the light cone?
eloheim said:Secondly, I have to admit, I was really surprised to see 'unitarity' (or rather the dispensation, thereof) held up beside 'locality' as a 'problem concept' to be eliminated(!). I would have expected exactly the opposite--I've always considered it (unitarity, that is) to be a pilar of physics beyond the standard model, and one of the key insights of recent times! Am I missing something with this?
Good catch. That part interested me very much as well, but somehow it got lost on the way to market when I put together my post.ddd123 said:I'd like to know more about this as well. How can we interpret systems in which the total probability isn't one?
eloheim said:Am I right to think that the disposal of 'locality' proffered in the article is closely related to the Holographic Principles/proposals associated with quantum gravity?
bhobba said:Two issues here. First its a populist account bereft of the technical detail - not that I think even if that detail was published more than a few specialists in the area would understand it anyway. And secondly the article is basically saying it needs further investigation.
MTd2 said:http://arxiv.org/abs/1312.2007
The Amplituhedron
Nima Arkani-Hamed, Jaroslav Trnka
(Submitted on 6 Dec 2013)
Perturbative scattering amplitudes in gauge theories have remarkable simplicity and hidden infinite dimensional symmetries that are completely obscured in the conventional formulation of field theory using Feynman diagrams. This suggests the existence of a new understanding for scattering amplitudes where locality and unitarity do not play a central role but are derived consequences from a different starting point. In this note we provide such an understanding for N=4 SYM scattering amplitudes in the planar limit, which we identify as ``the volume" of a new mathematical object--the Amplituhedron--generalizing the positive Grassmannian. Locality and unitarity emerge hand-in-hand from positive geometry.
eloheim said:Also, thanks for the tip on Wigner's theorem. I'll have a look.
