The law of conservation of energy is wrong?
The discussion revolves around the law of conservation of energy, particularly in the context of the universe's expansion and the implications for energy definitions and measurements. Participants explore concepts related to energy in relation to wavelengths of light, the effects of general relativity, and the challenges of defining simultaneity in different reference frames.
  • Some participants question the constancy of energy in the universe, particularly in relation to the expansion of the universe and its effects on electromagnetic energy and wavelengths.
  • There is a discussion about the formulas for photon energy, with some participants noting the difference between E=hλ and E=hf, and challenging the correctness of the units in these equations.
  • One participant argues that longer wavelengths correspond to lower energy, while another asserts that energy increases with wavelength, leading to confusion.
  • Concerns are raised about defining "one instant in time" in the context of conservation of energy, especially when considering classical mechanics versus general relativity.
  • Participants discuss the implications of general relativity on simultaneity, suggesting that simultaneity is not universally defined in this framework.
  • There is mention of the radiation density of the universe decreasing more rapidly than matter density due to expansion, and the potential for recovering lost radiation energy if the universe contracts.
Participants express multiple competing views regarding the implications of the universe's expansion on energy conservation and the definitions of energy and simultaneity. The discussion remains unresolved with no consensus on these complex topics.
Participants highlight limitations in defining energy at cosmic scales and the challenges posed by general relativity in understanding simultaneity and energy conservation. There is also uncertainty regarding the quantization of time and its implications for measurements.
This discussion may be of interest to those exploring advanced concepts in physics, particularly in cosmology, general relativity, and the nature of energy and time.
nibbel11
e few days ago i talked with my teacher about the energy in the universe being constant. but we were completely confused when we came to the concept of:
"because of the universe expansion everything moves away from each other. and the same goes for the wavelenghts in light. because of the way electro-magnetic energy is being calculated. the energy increases with the wavelength but isn't converted in anything."
is this right or not
if not where was our mistake.
what is even the formula of the energy of a phonton
E=hλ
or
E=hf
Longer wavelength is lower energy.
One problem with saying that the amount of energy in the universe is the same from one instant in time to the next is with defining the notion of one instant in time.
In classical Newtonian mechanics the notion of "at the same time" is taken for granted and conservation of energy works. In special relativity, the notion of "at the same time" depends on the coordinate system you choose but as long as you choose an inertial frame of reference, conservation of energy still works. But with general relativity and curved space time, there is no such thing as a globally inertial reference frame. The notion of "at the same" time becomes a matter of pure convention. Locally one can choose to use an inertial frame so that locally, conservation of energy still works. But globally, it does not.
This in addition to the problem with even properly defining "energy" at cosmic scales.
jbriggs444 said:
,, instant in time to the next is with defining the notion of one instant in time...
Well conventionally 'seconds' which can be measured by atomic clocks,
Ideally though we need to know if there is a quantized Planck time, either theoretically or in fact.
I won't be placing a bet on it.
Ideally though we need to know if there is a quantized Plank time, either theoretically or in fact.
Simultaneity has nothing to do with units of time.
Fair enough, does that imply that in GR, simultaneity is not defined?
Yes
The energy decreases with wavelength. But this still has the same problem. In fact, it is accepted that the radiation density of the universe has decreased more rapidly than the matter density of the universe because of this effect. Thermal energy is also reduced.
General relativity complicates things, but I think if you treat the universe as relatively smooth (using a fluid approximation), it is just a matter of defining an appropriate gravitational potential energy which accounts for the loss in radiation and thermal energy. Maybe this sounds like cheating, but the point is that if you contract the universe, you should be able to get back all the radiation energy that you "lost" by expanding the universe.
jbriggs444 said:
Yes
Yes too, but buses mostly do turn on time though (within acceptable limits of uncertainty)
E=hλ
or
E=hf
Check your units, E=hλ doesn't give the correct units for energy.
Indeed. The fact that GR does not prescribe a particular simultaneity convention does not preclude us from picking one that works locally.
thanks everyone that helped a lot
:dademyday:
  • · Replies 53 ·
  • · Replies 41 ·
  • · Replies 19 ·
