The length of a path on a sphere (in spherical coordinates)
The discussion revolves around calculating the length of a path on a sphere using spherical coordinates. The original poster presents a formula for the length of the path and expresses confusion regarding the inclusion of a sine factor in the calculation, indicating a potential misunderstanding of spherical coordinates.
  • Participants explore the relationship between spherical coordinates and path length, with some attempting to derive the length using parameterization and others questioning the geometric implications of the sine factor. There are discussions about the Jacobian matrix and its role in transforming coordinates.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some have offered guidance on the use of derivatives and the geometric interpretation of the problem, while others are still grappling with the details of the transformation and the implications of their calculations.
Participants note the importance of understanding the geometry of spherical coordinates and the potential for confusion when approaching the poles versus the equator. There is an acknowledgment of the need for clarity in the treatment of the variable φ in derivatives.
ks_wann
So, I'm to show that in spherical coordinates, the length of a given path on a sphere of radius R is given by:
L= R[itex]\int_{\theta_1}^{\theta_2} \sqrt{1+\sin^2(\theta) \phi'^2(\theta)}d\theta[/itex],
where it is assumed [itex]\phi(\theta)[/itex], and start coordinates are [itex](\theta_1,\phi_1)[/itex]and [itex](\theta_2, \phi_2)[/itex].
I've tried starting by letting ds be a short path segment, such that
[itex]ds=R \sqrt{ d\theta^2+ d\phi^2}[/itex] and [itex]d\phi=\frac{d\phi}{d\theta}d\theta=\phi'(\theta) d\theta[/itex]
But this is obviously wrong, since I'll be missing a factor of sin^2(θ). If I draw the situation, it's also clear that I'll need the factor.
Is it just a sphercial coordinate concept I'm missing, or am I way off?
If a curve is given by x(t), y(t), z(t), where t is a parameter, how is its length computed?
I'd use
[itex]s=\sqrt{(\frac{dx}{dt})^2+(\frac{dy}{dt})^2+(\frac{dz}{dt})^2}[/itex]
So I tried inserting x, y and z as spherical coordinates, and having θ as the parameter, in the end I end up with [itex]\sqrt{R^2}[/itex]. That's after I take the derivative with respect to θ.
I'm not sure I got your hint.
ds^2 = dx^2 + dy^2 + dz^2
To translate this into spherical coordinates in the form:
ds^2 = a*dr^2 + b*dθ^2 + c*dϕ^2,
you need the Jacobian matrix for the transformation, which will give you a, b and c. The result is rather well known, but if you're not familiar with the technique, i would recommend you look it up. Your problem is straightforward from there.
ks_wann said:
I'd use
Your approach is correct in principle, so there must be an error in details. Unless you show all the steps, I can't help.
It's a matter of geometry. As you approach the poles, the lines of constant longitude get closer together, and as you approach the equator, they get further apart. You need to draw a diagram to see why geometrically there is a factor of sin2θ.
I've looked it up, but it puzzles me how I go from [itex]ds^2=dx^2+dy^2+dz^2[/itex] when dx, dy and dz are added together. I mean, if it was [itex]ds^2=dx^2 dy^2 dz^2[/itex] it would be straight forward for me.
abs[∂(x,y,z)/∂(r,θ,phi)] * dr dθ dphi
Can I simply transform each on its own? dx, dy and dz?
With [itex]\theta[/itex] as the parameter, I insert [itex]x=r\sin\theta\cos\phi[/itex], [itex]y=r\sin\theta\sin\phi[/itex] and [itex]z=r\cos\theta[/itex].
This would give me
[itex]\sqrt{(\frac{d}{d\theta}r\sin\theta\cos\phi)^2+(\frac{d}{d\theta}r\sin\theta\sin\phi)^2+(\frac{d}{d\theta}r\cos\theta)^2}[/itex]
From there I end up with
[itex]\sqrt{r^2(\cos^2\theta\cos^2\phi+cos^2\theta\sin^2\phi+\sin^2\theta)}[/itex]
Using identities it reduces to [itex]\sqrt{r^2}[/itex]..
Do you understand that, for example, $$ \frac {d} {d\theta} \sin \theta \cos \phi = \cos \theta \cos \phi - \sin^2 \theta \phi'(\theta) $$
No, I can't figure out the last term on the right.
Voko, is your 2nd term correct? In my opinion it ought to be " -sin(theta)*sin(phi)*(dphi/dtheta)"
Darn, brain still half asleep :)
Indeed that should have been $$ \cos \theta \cos \phi - \sin \theta \sin \phi \phi'(\theta) $$
I see what you did there. So I should treat [itex]\phi(\theta)[/itex] properly in my derivatives.
Well, yes that was fairly easy. Thanks a lot. :)
Here's a simpler way. Draw a circle. Draw the z-axis vertically through the center of the circle. Pick a point P on the upper half of the circumference. Draw a radius from the center of the circle to the point on the circumference. Label the angle θ between the radius and the z axis. Draw a horizontal line from the point P to the z axis. The length of this line is R sin θ. So you see how this length is related to longitudinal distance around the z axis?
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 24 ·
