What Happens to x^i as x Approaches 0 from the Positive Side?
  • Thread starter Thread starter hddd123456789
    Limit
As x approaches 0 from the positive side, the expression x^i can be rewritten as e^(i ln x), which leads to oscillation on the unit circle in the complex plane. The notation "2i (0 to pi)" indicates that the function oscillates between -1 and 1 for the real part and between -i and i for the imaginary part. The limit does not exist because as ln(x) approaches -∞, the values of e^(i ln x) do not settle at a specific point but instead rotate around the unit circle. Thus, while the function's values are constrained to the unit circle, they do not converge to any particular limit. The key takeaway is that x^i does not have a limiting value as x approaches zero; it continuously oscillates.
hddd123456789
Hi,
I'm having to teach myself math and I guess I'm skipping ahead here but am really interested. For f(x)=x^i, the limit from the positive side I see from WolframAlpha is e^(2 i 0 to pi). Can someone please explain what the "2 i 0 to pi" means? Is it 2 times i times the set 0 to pi? Or something like that? And why is it 0 to pi? As it spins around going to zero, wouldn't it 'touch' the y-imaginary axis at one particular point?
Just thinking aloud...any help would be much appreciated :)
Mathematics news on Phys.org
You can rewrite xi as
$$x^i = e^{i\ln x},$$
assuming x is real. Do you know Euler's identity?
$$e^{iy} = \cos y + i \sin y.$$
With these two pieces of information, can you see what happens as x tends to zero from above?
The limit doesn't exist. However, for all positive real x, xi is constrained to lie on the unit circle. That is all you can say about the limit, and that is all that Mathematica is saying. e2i (0 to pi) might be better written as e^{i\theta}, 0\le\theta<2\pi.
hddd123456789 said:
Hi,
"2 i (0 to pi)" means "oscillating on the range 0 to 2*i*pi".
The real part of x^i is oscillating on the range -1 to 1
The imaginary part of x^i is oscillating on the range -i to i
Yes! I had actually tried to change x^i into Euler's identity, but not only was I unable to do it at the time, I see now that it likely wouldn't have helped without the x^i = e^i*ln(x) relationship.
Basically ln(x) goes to -∞ and e^i(-∞)=cos(-∞) + i*sin(-∞), and Euler's identity only gives specific y-imaginary values for particular values of x. But since ∞ isn't a particular value of x, but an arbitrarily large value, you can't say anything specific about the limit except that it lies somewhere on the unit circle. Is that the right way to think about it?
You can say something specific about the limit: it doesn't exist. The functions ##\sin x## and ##\cos x## have no limit as x approaches infinity, so this tells you that ##x^i## has no limiting value, its value just twirls around the unit circle in the complex plane faster and faster as x grows larger.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
