The meaning of z number in red shift
  • Thread starter Thread starter kc2dws
    Red shift Shift
The discussion clarifies that the "z" number in redshift represents the cosmological redshift, which measures how much the universe has expanded while light was in transit, rather than a direct measure of relative speed. Specifically, the formula 1 + z = a_now/a_then indicates the ratio of current to past distances, where a z value of 1 signifies that distances have doubled since the light was emitted. The conversation emphasizes that this expansion is not akin to ordinary motion, as all objects are moving away from each other. The relationship between z and the emitted and received wavelengths or frequencies of light is also highlighted. Understanding the z value is crucial for interpreting observations of distant galaxies and cosmic phenomena.
kc2dws
Hello
I understand that red shift is a measurement of relative speed. What I am looking for is what the number after the z means. Is it a percent of c or, Or is it it just a scale that physics uses to note the difference between different objects.
Thanks for your time.
Kevin
Astronomy news on Phys.org
As I understand it, it is simply as you said the relative difference between the observed and emitted frequencies.
The basic difference is the background temperature of the universe 'then' vs temperature now. For example, the background temperature at z=2 was nearly three times hotter than we now measure [a z+1 thingy].
Thank you doth for your reply's
kevin
kc2dws said:
Hello
I understand that red shift is a measurement of relative speed...
Kevin
Mostly not. Most of the redshift that is observed and that we talk about here is not Doppler redshift (depending on relative speed at some given instant of time.)
Mostly we talk about cosmological redshift. Technically different. It is a measure not of relative speed at some time but instead measureshow much distances have expanded while the light was in transit.
You will see that in the Wikipedia article that Drakkith gave link to, if you look far enough down the page. You will see a table and one of the entries will be "cosmological redshift".
that is the z we are talking about when we talk about the observed redshifts of distant galaxies. Or Type Ia supernovae with z = 1 or z = 1.5
Or quasars with z = 6. Or cosmic microwave with z = 1100. That is all cosmological redshift.
The formula does not involve speed. It involves the ratio of distance now/distance then.
z = 1 means that on average a largescale distance DOUBLED while the light was in transit.
You always add one to z to get the ratio by which distances have increased.
1+z = anow/athen you can find that in the Wikipedia Drakkith gave you
In other words if z = 2 then distances have TRIPLED while the light was in transit to us.
they are 3 times longer NOW on the day we receive the light than they were THEN when the light was emitted by the glowing gas or star and started on its way to us.
the general pattern of expansion is not like ordinary motion because nobody gets anywhere by it (everybody gets farther from everybody)
and the rate of expansion has been constantly changing all during the time the light has been traveling, so there is no one obvious rate to pick that would determine z.
Thank you marcus.
I reread the article, And found the equation
z is related to the scale factor of the universe by
marcus said:
1+z = anow/athen
and also to the emitted and received wavelengths (and frequencies) of light (for galaxies moving with the Hubble flow).
z =\frac{a_{now}}{a_{then}} - 1 = \frac{a_{now} - a_{then}}{a_{then}} = \frac{\lambda_{now} - \lambda_{then}}{\lambda_{then}} = \frac{f_{then} - f_{now}}{f_{now}}.
  • · Replies 46 ·
  • · Replies 23 ·
  • · Replies 19 ·
