The Method of Images (Electromagnetism)
The discussion centers on the Method of Images in electromagnetism, specifically addressing the concept of grounding and its relation to electric potential. Grounding a conducting plane establishes it at zero electric potential, allowing it to accept charge without altering its potential. While the method typically assumes an infinite conducting plane for simplicity, finite planes can be used with more complex calculations. The grounding process is a mathematical convenience, as only potential differences are physically significant.
  • Understanding of electric potential and grounding concepts
  • Familiarity with the Method of Images in electromagnetism
  • Basic knowledge of electrostatics and conductors
  • Mathematical skills for solving potential problems in physics
  • Study the implications of grounding in electrostatics
  • Explore the Method of Images with finite conducting planes
  • Learn about electric potential differences and their physical significance
  • Investigate advanced applications of the Method of Images in complex geometries
Students and professionals in physics, electrical engineering, and anyone interested in understanding the principles of electromagnetism and electric potential management.
sinus
TL;DR
What is the effect of the plane that being grounded make its electric potential become zero?
Can anyone explain to me why grounded means zero electric potential. I confuse what's the relation between infinite ground conducting plane and its electric potential (the method of images).
I have a several question:
1. Why the conductor plane must be infinite, while in reality there's no such one.
2. Why the electric potential must be zero to using this method?
2. If the plane isn't be grounded, does its electric potential not zero? What's exactly that making the potential in the plane zero when we grounded it? How ?
As far as I know that the electron easily run into the ground, does it mean the plane become positive charge?
It's arbitrary what you define to be zero because only potential differences matter. If there is a ground connection then that's usually defined to be zero.
There is too much context missing to answer your individual questions.
1. Conducting plates don't have to be infinite in general.
2. Which method?
Because it makes the calculation easier. A large but finite plane would give approximately the same answer, but with more mathematical effort required.
Because it makes the calculation easier. You can set it to any potential you like, but setting it to zero is convenient.
Grounding allows the plane to accept charge without changing potential. So grounding produces a structure with a fixed potential. It is merely a mathematical convenience to set that fixed potential to zero.
It is just an arbitrary choice. The value of potential is not physical. Only potential differences are physically meaningful.
No. As I said above, grounding makes it so that the plane has a fixed potential which does not change as charges are added or removed.
2. Which method?
Thank you for your reply sir, I finally understand the method of images. Sorry for long tome didn't respond. For your feedback,number 2: the method that I meant is the method of images, like why using that solutions method (thank god, now I know the reason)
For number 1, I don't follow. So for a finite conducting planes the method of images is still apply?
Thank you so much for your explanation sir, it really helpful for me :)
