The Molar Specific Heat (internal energy)
5 replies · 5K views · last reply
rey242
One mole of an ideal diatomic gas undergoes a transition from. a to c along the diagonal path
What is the change in internal energy?
I've tried to use the two other paths since the internal energy is the same both ways, but I can't see anyway to reconcile the two.
  • PV diagram with pressure in kN/m^2 on the vertical axis (2.0 and 5.0 marked) and volume in m^3 on the horizontal axis (2.0 and 4.0 marked). Points a (2.0, 5.0), b (4.0, 5.0) and c (4.0, 2.0) are joined by green arrows: a to b horizontal, b to c vertical, and a diagonal from a to c.
You can use that equation to solve this problem. You just need:
1. the temperature change between points a and c
2. Cv
3. n
I figured it out... but now I need to find the work done and the total heat entered into the system. I know it has to do with
U=Q-W
and the use of the other path(ABC).
Yes, you'll need that equation (U=Q-W). You can also use the fact that W is the area under the curve in the P-V diagram.
