The necessary inclined force to rotate an object around an axis
The discussion revolves around the mechanics of rotating a door around a pivot using an inclined force. Participants explore the relationship between the angle of the applied force, the distance from the pivot, and the force required for rotation.
  • Participants discuss the need to specify the angle α to determine the force F. There are considerations regarding the optimal angle for applying force and the implications of the distance from the pivot. Some participants question the assumptions about the door's orientation and the effects of friction.
The conversation is active with various angles of approach being considered. Some participants have provided insights into optimal force application, while others are clarifying their understanding of the problem setup. There is no explicit consensus yet, but productive dialogue is ongoing.
Participants are navigating constraints related to the physical setup of the door, including its weight and the nature of the pivot. There are also discussions about the implications of design choices in door functionality.
chane
I just want to ask if is it possible to find the force F, the angle "alpha" and the distance between the force F and the pivot just with the door weight. Or I have to make an assumption of the angle or the distance.
Btw the object lenght is 2150mm
Fy = F*sin(alpha)
:welcome:
Can you explain what you are trying to do?
I am trying to rotate the door around the pivot (red dot) using an inclined force
Then you have to specify ## \alpha ## if you are to find the force ## F ##
... The required force depends on both the angle ##\alpha## and the point at which the force is applied. For physical reasons it's optimum to have ##\alpha = \frac \pi 2## and ##F## applied as far from the pivot as possible. Your equations should lead to the same conclusion.
So I have to suppose alpha and make my calculation around it
Thanks now i get it
Last question how do i write "alpha" as a the symbole (i'm new )
That is why people who design doors cleverly put doorknobs and handles as far away from the hinges as possible. Quite often in public places one also sees instructions of use, e.g. "PUSH" or "PULL".
They're not quite so clever when it comes to the height of the doorknobs, which are usually far too low!
I am not so sure. It's possible that the height of doorknobs has been influenced by universal design principles. They have to be accessible to all, including persons with dwarfism, children and perhaps dogs trained to bring in one's newspaper.
  • Skeptical
Just checking... your diagram implies this is a trapdoor, not an upright door, yes? So the further from the hinge the force is applied, the smaller the angle will necessarily be. I.e. ##d\sec(\alpha)## is fixed as the string or arm length.
If you want to take friction into account, note that ##F\cos(\alpha)## contributes to the normal load at the pivot.
  • · Replies 95 ·
  • · Replies 28 ·
