I The Physics of unloading sand from a barge
  • I
  • Thread starter Thread starter oz93666
    sand turbulance
The discussion focuses on the efficiency of unloading sand from a barge using water jets. It emphasizes the importance of maintaining water velocity to keep sand suspended, suggesting that directing the hose towards the outlet and creating narrow channels can enhance efficiency. The conversation also highlights the need for a high volume of water to transport the sand, as well as the economic factors involved, such as local wages and diesel costs for the pump. Additionally, it references the use of similar methods in the lower Mekong River and mentions the elegance of gravity-assisted unloading techniques. Overall, the participants are exploring ways to optimize the sand unloading process.
oz93666
TL;DR Summary
How to efficiently move sand with water jets.
I think it's easist first to watch a short vidio clip
I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way?
The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water velocity , it will dislodge the sand but it will be more likely to settle out elsewhere and need moving again ...
Another way to maintain velocity is to carve narrow channels (with the water jet) to the exit point , wide expances of flow reduce velocity.
Any thoughts ?
They are moving the sand to the pump inlet using water jets. The volume ratio of water to sand, in order to be pumped, requires that high volume of water. The water volume that is needed to pump out the sand, is more than sufficient to dislodge and transport the sand within the hull.
The same pump, being used here to unload the bulk sand, would have been used to load the sand earlier, at the suction dredge site in the navigable channel.
The river has plenty of water to circulate. The cost of wages for local employment is not too high, and almost all of those wages circulate within the local economy. The cost of the diesel needed to run the slurry transfer pump cannot be reduced. How could the process be made more efficient?
Transport of sand like that is used throughout the lower Mekong River. There is the regular YouTube 'Nguyen Che Linh Channel', video from the Tra Vinh dam, that shows the almost over-loaded transport barges, with their slurry pumps, fighting to get from the tidal to the fresh water navigable river.
An example:
Likes sophiecentaur
I love to watch dredgers dumping silt out of the hull by opening doors in the bottom. Very elegant to let gravity do the work. The ship slowly rises up out of the water.
The guys doing the job don't seem to be working efficiently. Was there any staff training involved? They seem to be splashing water everywhere with no particular end in view. It's the same problem that you get trying to get rid of sand from a shower tray; it just won't do what it's told. But do we ever ask about where the sand hides when it's in the pipes?
Maybe the economy can't support a 'proper' bottom-unloading dredger. For them, it's all over in a couple of minutes.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
I don't need cloth simulation. I need to simulate clothing meshes. Made of triangles and I need an answer that someone with High School math can understand. I am actually using the time it takes for someone to answer to create a model with less geometry than the one I have been using. I want clothing that can be removed on a model that will be animated. I don't need stretching or wrinkles on my meshes, I just need gravity. I have an idea of how I could do it, but I don't know how to apply...
