The postulates of Special Relativity
Debdutta
According to the first postulate of Special Relativity, all the laws of physics are symmetrical in all inertial frames. So that also means that Maxwell's equations are true in any such frame (experimentally verified). Now we can easily uncouple the four first-order differential equations in free space and that leads to two second order differential equations (in fact six) for the electric and magnetic fields, the wave equations, with the speed of such waves being that of light, which is precisely a constant, depending only on the permitivity and permeability of free-space. So my question is, what is the need of the second postulate if it is easily derivable from the first? It is a radical conclusion, but not an independent assumption, or is it?
Einstein did not want to assume Maxwell's equations. What if they were superseded? In fact, the were superseded by QED, while special relativity survives unchanged. Another way to look at it is the axiomatic framework chosen by Einstein acts to constrain any possible future theories of physics - they must be Lorentz invariant.
Another reason to not assume Maxwell's equations is that this would make SR a theory of electromagnetism. It's much prettier to define it as a model of space and time that serves as a framework in which we can define theories of particles, fields and interactions, like for example classical electrodynamics (Maxwell's equations).
I see. Thank you PAllen and Fredrik. I got my answer.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
