The Primacy of Conservation Laws: Rethinking the Concept of Force in Mechanics
The discussion centers on re-evaluating the concept of force in mechanics, proposing that conservation laws should be the foundational principle instead. It argues that force is merely a term for the rate of momentum transfer, which simplifies Newton's laws and aligns better with modern physics. The conversation highlights that many advanced physics frameworks, such as Lagrangian and Quantum Field Theory, prioritize conserved quantities over forces. Participants also note that while forces can exist without momentum transfer, understanding momentum flows can clarify interactions. Overall, the thread advocates for a shift in perspective from force as a primary concept to one focused on conservation and momentum transfer.
russell2pi
Hello,
I am hoping for some input concerning shall we say the philosophy of mechanics, particularly with relation to the concept of force.
Most textbooks treat force as being something of a primary concept. A fundamental aspect of nature much like energy and mass and therefore something which cannot be readily defined, merely related to other concepts by rote application of Newton's laws.
To me it's not really. To me the conservation laws, and the quantities to which they refer, are the more sensible choice of foundation upon which to lay a conceptualisation of reality.
The explanation I have sketched out of force, then, is roughly as follows
- certain quantities are found by experiment to be conserved. For now, mass-energy, momentum and charge will do
- conserved quantities are really useful because we can think of them as being transferable, and transferable with quantifiable amounts and rates
- force is just a name for the rate of transfer of momentum
- "a" force is an influence upon the rate of transfer of momentum
To me this
- is simple
- makes Newton's laws seem like stating the obvious (2nd by definition, 1st=special case of 2nd, 3rd by definition as every transfer has a source and a sink)
- explains jet force in a way that is much more direct than appeal to Newton's 3rd, and reduces jet "force" to just a way of talking about straightforward momentum transfer
- is consistent with the standard model of particle physics and more broadly (by conservation of 4-momentum) with general relativity
To me the primacy of force is a long-obsolete hangover from the days when "contact force" was still considered a viable proposition. Recasting contact forces in terms of the Colomb interaction to me kind of forces the issue towards the above conceptualisation.
My only quibble is I'm kind of making this up as I go, wilfully ignorant of accepted views of the matter. I have not heard of such a conceptualisation clearly stated from any other source, although to me it seems implicit in the Standard Model -- or perhaps explicit, if you read the right books? But then again I've just picked up Feynman Lectures on Physics Vol 1, which includes a chapter on Characteristics of Force. Feynman -- who, of all people, you might expect to view force as nothing more than a transfer of momentum by gauge bosons or otherwise -- says nothing of the sort and just really seems to throw up his hands and say it's all too complicated(!)
So I guess I would like to know whether a) this view makes any sense and b) where are some good places to start reading about this approach as used by smarter people than me?
Your reasoning is essentially correct, and that kind of thinking is part of what got us from Newtonian Mechanics to more advanced physics. If you look at Lagrangian Mechanics, Classical Field Mechanics, or Quantum Field Theory, you deal primarily with energy and momentum - the conserved quantities. Forces can be extracted from solution if you need them, but the concept of a "force" is not directly used in solving a problem.
If you look deeper, into things like Quantum Electrodynamics and Quantum Chromodynamics, you see that even conservation laws aren't fundamental. What's fundamental are certain symmetries. From each fundamental symmetry arises a conserved current and gauge fields that carry forces. So you end up with both conservation laws and forces as a consequence of symmetries. The mathematical formulation of this comes from Noether's Theorem.
In classical physics, invariance of the laws of physics under translation gives you conservation of momentum. Under time - energy. Under rotation - angular momentum. Since only global symmetries are considered, you don't really get a gauge field.
In Quantum Electrodynamics, the U(1) local symmetry gives you both the conservation of electrical charge and the electromagnetic forces that couple to this charge.
If you conceptualize force as rate of transfer of momentum then you run into difficulty in scenarios where force is present but no transfer of momentum is taking place. An example would be leaning against a wall. There is a force between me and the wall, and an equal and opposite force between my shoes and the floor. The net force on me, as a whole, is zero but the forces are not applied in the same place which creates strain on both me and the floor/wall.
And there is a corresponding momentum flow as a result. You->wall->floor->you.
Would you like to put up some maths to back up this proposal?
Lovely -- I started to draft a reply but got bogged down in detail. You've said it in a nutshell.
Balanced forces are balanced momentum flows. As with flows of mass or charge, you can have flows occurring without any net accumulation or depletion in any body.
As for the strain - it's essentially Hooke's Law. The (directed) rate of momentum flow by the Coulomb interaction between molecules depends on their separation. Their equilibrium separation (strain) therefore depends on the (directed) rate of momentum flow they are required to sustain (tension or compression).
Thanks K^2 for your earlier post, too -- yet more impetus for me to get around to learning about symmetry in physics. Nice to know I'm intuitively on the right track (if only in a tiny way) Any suggestions for introductory books or materials, suited to a time-poor person, would be gratefully received!
True, but modeling strain in terms of momentum flow is awkward. At least it is to me. Modeling inelastic collisions in terms of force would be equally awkward. It's best not to get stuck on one idea. Be familiar with a wide variety of conceptual tools so you can pick the best one for any given job.
So dp/dt = F isn't enough? I understand that you might be tempted to point out that dp/dt = ƩF, and ƩF=0. But do keep in mind that d/dt is a linear operator, and we need to decompose it if we want to look at individual flows rather than the net change.
Or do you want me to go deeper and write out some Feynman diagrams for a virtual photon exchange, showing that any application of force results in momentum flow?
Or do you need me to go a step deeper and derive relation between stress tensor and momentum flow? If you want me to be creative, I can do that using the fact that stress tensor is a conserved quantity under coordinate transformation, while angular momentum is a conserved quantity under rotation specifically.
When you are asking about something so fundamental as momentum flow due to an interaction, I really don't know what sort of level of math you are looking for.
Well, I don't think you need go as far as a person leaning.
Just a 1Kg mass sitting on a table in a gravitational field will do, although the analysis presumably also applies to anybody force.
And granted that the table initially deforms minutely when first placed, but considering only the subsequent steady state.
And please look again at the title of the subforum and ask yourself if at least some of your responses would be more appropriate if this were one of the more advanced physics subforums.
Valid point on section. I'll stick to classical.
For a mass supported by a normal force in a gravitational field, again, you are looking at two flows. Body receives upwards momentum to normal force and looses it to gravitational force. That lost momentum is transferred to Earth via gravity and is returned back via forces of deformation into the support surface. There is still a net flow, even if you consider this classically.
Are you implying that there can only be continuous deformation without limit?
I fail to see what this extra layer of complication adds.
It simplifies, not complicates.
Define momentum, posit that it is conserved, and that's all you need. Newton's laws become 1) stating the obvious, 2) a redundant definition and 3) stating the obvious.
Where it doesn't seem to help, just substitute the word "force" where you see "flow of momentum". They mean the same thing. The word "force", while redundant, is still a useful shorthand for sources of momentum flow, since many problems can be analysed in terms of forces (discrete sources of momentum flow) where an expression can be found relating the size and direction of force (i.e. rate and direction of flow) to other quantities.
It's also more than just a simplifying framework. It says that momentum transfer is primary, and force is just a name for it. Compare to the usual Newtonian view that force is primary and that force causes the transfer of momentum. You all know a lot more about modern physics than I do, but I figure this is closer to the current understanding ... isn't that why we now speak of "fundamental interactions" and not "fundamental forces"?
It resolves this "difficulty". If there is an interaction force, there is a transfer of momentum taking place. Just like net force can be zero, net transfer can be zero.
Naturally, if the net transfer is zero, we don't need to actually worry about each individual interaction. And that's precisely how it would be formulated in, say, Hamiltonian mechanics. \dot{p}=\{p,H\}. No need for concept of force as such. And yeah, no need for complication of tracking momentum transfer due to each interaction individually.
Thank you both for telling me that at some underlying and fundamental level that the use of a self consistent system of mechanics, developed over several centuries, is either somehow wrong or can be simplified.
There are other subforums here for such discussion.
This subforum is all about the classical system I just described.
I do not know of any text on structural mechanics or bridge design that follows this modern route to success.
In fact I cannot recall any bridge design text using the word momentum at all.
Many fluid mechanics texts use the phrases "destruction of horizontal momentum" and "appearance of vertical momentum" to descibe what happens when a flowing fluid is directed at a wall.
I ask for a mathematical description, equivalent to the classical analysis, using the modern theory to compare and see if it is actually simpler and easier, as claimed.
russell2pi said:
Hello,
I don't understand your "not readily defined". In classical mechanics these things except for energy are (were?) rather well defined, with balances, scales and rulers - thus there were not so long ago the kg (for mass) and the kgf (the force by one kg on Earth). Perhaps that was the reason for the primacy of those in classical mechanics. "Energy" is a hard to measure concept, it started out as a bookkeeping value.
K^2 said:
[..] For a mass supported by a normal force in a gravitational field, [..] you are looking at two flows. Body receives upwards momentum to normal force and looses it to gravitational force. [..] There is still a net flow, even if you consider this classically.
:bugeye: Momentum ("quantity of motion"): p=mv
"The Quantity of Motion is the measure of the same, arising from the velocity and quantity of matter conjuctly."
https://en.wikisource.org/wiki/The_...of_Natural_Philosophy_(1729)/Definitions#Def2
In classical mechanics, stationary v=0 => p=0. Or if in inertial motion, p=constant.
No "momentum flow" in classical mechanics: it is a conserved quantity, not a fluid.
- "a" force is an influence upon the rate of transfer of momentum [..]
Not force in general, but what Newton called "impressed motive force" was defined just as you propose to do:
F=dp/dt "The alteration of motion is ever proportional to the motive force impressed".
Of course, the conservation laws that were developed from classical mechanics played an increasingly important role in history; indeed one can turn things around in a convenient way, based on modern knowledge.
Please elaborate: how does the Coulomb interaction affect Hooke's law?
[..] I've just picked up Feynman Lectures on Physics Vol 1, which includes a chapter on Characteristics of Force. Feynman -- who, of all people, you might expect to view force as nothing more than a transfer of momentum by gauge bosons or otherwise -- says nothing of the sort and just really seems to throw up his hands and say it's all too complicated(!)
[..] where are some good places to start reading about this approach as used by smarter people than me?
I don't have that book at hand, it will be interesting to look up. :smile:
And I did not look into that myself more than standard textbooks, but perhaps this is a good starter ("what else"!):
http://en.wikipedia.org/wiki/Conservation_law
Lagrangian and Hamiltonian Mechanics are topics in Classical Mechanics. I'm not sure what your complaint is.
You are trying to artificially limit discussion to a static case. First of all, yes, any structural mechanics problem can be solved using Lagrange Multipliers without talking about forces. Of course, what you are actually analyzing is stress, so you have no choice but to involve forces at some point, and you might as well start balancing forces from the beginning.
Dynamics problems, however, are greatly simplified by use of Lagrangian and Hamiltonian Mechanics in generalized coordinates. That's kind of why you usually learn them in a Classical Mechanics course.
But hey, if you want Lagrangian analysis of a mass supported by the floor, here it is.
Lagrangian and constraint.
L = \frac{1}{2}m\dot{y}^2 - mgy + \lambda f(y)
f(y) = y-H = 0
Equations of motion.
\frac{\partial L}{\partial y} - \frac{d}{dt}\frac{\partial L}{\partial \dot{y}} = \lambda - mg - m\ddot{y} = 0
\ddot{y} = 0
Solution.
\lambda = mg
Why is this simpler? Because I did not have to stop and ask what forces are acting on the body and what I need to do to have them add up to zero. Sure, with one body it's easier to just balance forces. What if you have a dozen different bodies with different constraints between them? Still feel like setting up all of these equations? In contrast, I can just write down the Lagrangian, write down the list of constraints, and just feed the whole mess into Mathematica to be solved. This method completely eliminates the need to go through each degree of freedom by hand.
And by the way, this is how you solve a problem with constraints. That is the standard approach used for the past 200 years. I don't know if that qualifies as "modern theory" in your books. Maybe you're still going by Principia as the only text on classical mechanics.
K^2 said:
[..] Why is this simpler? [..] I can just write down the Lagrangian, write down the list of constraints, and just feed the whole mess into Mathematica to be solved.[..]
:smile: (sorry couldn't help it!)
Is this a physics forum or an engineering forum? As stated in the OP, this is about the philosophy of mechanics. The change is of entirely no consequence when it comes to calculation. It's just a way of thinking about what you actually mean when you use the word "force". Do you say it "just is" or do you explain it as something that emerges from something else that "just is"?
As we say where I come from ... "no need to get you knickers in a knot!"
Alteration of motion is momentum flow. If you object to the word "flow", that's why the third law is there. Whatever momentum is lost by one object is necessarily gained by another - it flows from one to the other any time a force is acting. I doubt Newton would dispute that. The issue is simply whether the force causes the flow, or the force is just a name for the flow.
Is this the Science Advisor's reply to the following?
@ russell2pi
I clearly have a different definition of the principle of conservation of linear momentum than whatever you are thinking of.
harrylin, you solve a lot of many-body problems analytically? Every single real world application of principles of physics is numerical. So yes, ability to take your problem and put in the form you can feed to a solver of some kind is what determines whether the method is useful or not.
Studiot, do you have a point? You are jumping all over the place and making counter points that have no common thesis.
OP asked about forces. Fact is, nearly all of the physics has moved away from the force as a primary concept. Even in Classical Mechanics, once you move past Newtonian Physics, individual forces is not something you frequently consider. Newton's Laws have their applications. They do make many problems simpler. But they are neither the dominant explanation nor a dominant method even in mechanics. Hamilton's Principle and Conservation Laws are used instead.
I have provided arguments and explanation for this position. You just pick at individual phrases rather than have any sort of kind of point. That's not how you construct a counter-argument.
I'm not going to apologize for being an engineer, and I'm quite happy to solve problems using Lagrangian mechanics, or by hitting something with a 20lb hammer - whichever is the more effective tool to solve for the problem in question.
Limiting yoursefl to only one philosophical toolkit doesn't have any advantage than I can see. The more ways you can use to intuitively "see" what's going on the better, IMO.
K^2 said:
[..] ability to take your problem and put in the form you can feed to a solver of some kind is what determines whether the method is useful or not.
I think that usefulness is not what Studiot meant with "simple"; he can tell us. And of course, russell2pi can tell us if that is what he/she is after.
Thus you agree with me that Newton's second law describes force like you do? (note that I wrote mistakenly "defined" while it is a law which was found to be inaccurate for high speeds with the classical definition of mass).
However, as others already mentioned, no momentum is lost or gained by an object in static cases that force is applied. Force is in classical mechanics a more general concept than change of momentum.
Do the links help or do you need more?
PS You forgot to elaborate how the Coulomb interaction affects contact force and Hooke's law.
It doesn't matter. Any criterion you put on it, in general, Lagrangian approach wins out. That's why it was invented and why it was used to solve more advanced problems. Newtonian mechanics is only simpler with very simple choices of DoF, coordinate systems, and constraints. Poor generalization is a good indication that the set of laws is not fundamental. That's the criterion on which we chose one model over another. If you just look at the Sun, it's easier to say that Sun goes around the Earth. But if you throw in the planets, Geocentric system becomes impractically cluttered. It's the same kind of principle.
Lagrangian mechanics generalizes trivially. Newtonian mechanics does not.
Any possible continuous symmetry can be described by the invariance of lagrangian under certain transformation.It is really helpful when one does not get ideas from Newtonian eqn.lagrangian can be written down without having much detail of forces which is certainly not the case with Newtonian mechanics.
Since those who believe momentum to be one of the fundamental quantites have avoided my previous question about fluid dynamics I suppose that they will avoid this simple one as well.
Consider an isolated universe, empty except for a single particle.
What is the momentum of that particle?
You did not actually ask a question about fluid mechanics. Nor do you have a thesis still. What exactly are you arguing? What are your points and what are your arguments for these points?
Because I don't know your thesis, I am forced to guess your point about a lone particle. I'm guessing, you are trying to say "Force is absolute. Momentum is not." Well, you are wrong. If you take Relativity into account, force is frame-dependent just like momentum is. If you don't, then in Classical Mechanics I'm free to chose an absolute coordinate system and measure absolute momentum. Yes, even for one particle in the universe. So either both are relative or both are absolute depending on the kind of physics we are talking about.
That depends on the reference frame. Momentum is not an intrinsic property of a particle.
The quote below will be the third time (in this thread) I have posted this and the quote above will be the second time (in this thread) you have incorrectly reported my posts in an abusive manner.
  • #31
Fluid dynamics is derived from classical field theory. I still have no idea what it is that you are asking. The entire topic is an example of how you work with momenta directly without ever considering forces.
  • #32
I mentioned the word "force" precisely once in this thread, and that was before I asked a fluid mechanics related question.
On my last question.
In my opinion momentum in my uniparticular universe is indeterminate since the particle's velocity is indeterminate.
  • #33
It is frame variant, but not indeterminate. In any given frame it has a definite velocity and therefore a definite momentum.
  • #34
A definite velocity relative to what?
  • #35
Relative to the reference frame. That is how velocities are always defined.
  • #36
So where in this empty infinite universe is the origin of this reference frame?
  • #37
Wherever you choose, that is one of the decisions you have to make when you define a reference frame.
  • #38
...you define a reference frame.
But I didn't, becuse there isn't one, or alternatively one can't.
If we let the velocity of the particle be v or 1010v, what difference would it make to this universe (or the particle)?
  • #39
Huh? What would make you think that? There are an infinite number of reference frames you can define.
It would change the momentum and any other frame variant quantities. It would not change any frame invariant quantities.
  • #40
What is your thesis. State it clearly. You are not arguing a point right now, you are just bickering about stuff. That is not a way to have a conversation.
Classical Mechanics is non-Relativistic. There is an absolute velocity. Fact that you aren't specifying velocity just means that you don't know its velocity, because you are being intentionally shifty about posing the question.
In Classical Mechanics, a particle has a determinate position x,y,z for any given time t. I can take position between two times and obtain velocity. That's it. If you insist that velocities are relative, then you are the one who is not sticking to the constraints of Classical Mechanics.
Now, you might be tempted to bring up Galilean Relativity, but it's not true relativity in sense that it is indistinguishable from preferred system. Just because I can re-write equations doesn't mean that particles doesn't have an intrinsic absolute velocity. It is only when you start considering motion of light relative to other objects that the concept of velocity as relative quantity becomes irrefutable. But by now you've ventured into Special Relativity where force is a relative quantity as well.
  • #41
How did you get mgy?
Isn't it simpler to just write down mass times acceleration, and be done with it?
  • #42
For a mechanical system, Lagrangian is equal to total kinetic energy of the system minus the total potential energy of the system. Later gives you the mgy term. There is also a term that goes with lambda. That's due to the constraint.
Mass times acceleration is easier when you have a trivial degree of freedom with a trivial constraint. The more general problem becomes, the more effort it becomes to write out the correct equations for each DoF. In contrast, you can always write down the Lagrangian with the same amount of effort, and get the equations of motion by differentiating.
