The Yo-yo problem: Please help.
  • Thread starter Thread starter wr8899
The problem involves a yoyo with specified mass, moment of inertia, and dimensions, placed on a rough surface and subjected to a horizontal force while rolling without slipping. The questions focus on determining the acceleration of the center of mass and the friction force acting on the yoyo.
  • Mixed
  • Participants discuss the application of Newton's laws and torque equations, with one participant attempting to derive the acceleration and friction force. There is a focus on the ambiguity regarding the position of the string relative to the center of mass, leading to questions about the impact on torque direction and calculations.
Multiple interpretations of the problem setup are being explored, particularly concerning the position of the string and its effect on torque. Participants are engaging in clarifying assumptions and discussing the implications of different setups on the equations used.
There is an ongoing discussion about the conventions for torque direction and the specific details of the problem setup that have not been clearly defined, which may affect the analysis.
wr8899
A yoyo of mass m= 2 kg and moment of inertia I_cm= 0.0625 kg m^2 consists of two solid disks of radius R=0.25 m, connected by a central spindle of radius r=0.1875 m and negligible mass. A light string is coiled around the central spindle. The yoyo is placed upright on a flat rough surface and the string is pulled with a horizontal force F= 22 N, and the yoyo rolls without slipping.
(a) What is the x-component of the acceleration of the center of mass of the yoyo? (in m/s^2 )
(b)What is the x-component of the friction force? (in N)
F = ma, torque = I*alpha, a = R*alpha
I tried to solve the problem this way:
Using F = ma, and the given, I had F - friction force = ma, with friction force = 22 - 2a. With torque = I*alpha, I got 0.25*friction force - 0.1875*22 = 0.0625*alpha.
To put them all together, I got this equation, R(22-2a) - 0.1875*22 = (0.0625/0.25)*a
And then plugging the given, I got a = 1.83 m/s^2, but I don't think I'm doing this correctly.
Can someone please help me figure out where I went wrong right away. Thanks so much, sorry to be a bother here.
There's an ambiguity in the question. Is the horizontal string tangential to the spindle above or below the centre of mass? Taking it to be below, I get the same answer as you did. (The easiest way is to take moments about the point of contact with the ground - then you don't need to consider the frictional force.)
What difference does it make if it is above the centre of mass?
It affects the direction of the torque produced by the string about the center of mass.
So in this instance, how would the formulae change?
The signs of the torque terms depend on your conventions for positive and negative torque and whether or not the string is being pulled to the right or to the left as viewed from the side. You haven't specified these details. Once you are clear on the setup, you should be able to decide if a particular torque is positive or negative when setting up the equation.
If you use my approach, taking moments about the point of contact with the ground, you will see that the moment of the tension in the string changes because the distance is either R+r or R-r.
  • · Replies 21 ·
  • · Replies 42 ·
  • · Replies 49 ·
10K
