Theoretic doubt about the definition of derivatives.
The discussion centers on the necessity of using the definition of derivatives in certain cases, particularly when dealing with functions that exhibit problematic behavior at specific points, such as (0,0). The example provided involves the function f(x,y) defined as (y³)/(x⁴ + y²) for (x,y) ≠ (0,0) and 0 for (x,y) = (0,0). It is established that while derivative rules offer efficiency, they may not apply when division by zero occurs, necessitating the use of the definition to accurately compute partial derivatives at troublesome points.
  • Understanding of calculus concepts, specifically derivatives and partial derivatives.
  • Familiarity with the definition of a derivative in multivariable calculus.
  • Knowledge of limits and their application in calculus.
  • Ability to identify and analyze functions with discontinuities or undefined behavior.
  • Study the definition of partial derivatives in multivariable calculus.
  • Learn about the implications of discontinuities in functions and how they affect derivative calculations.
  • Explore the concept of limits in greater depth, particularly in relation to derivatives.
  • Investigate examples of functions that require the definition for derivative calculation, such as piecewise functions.
Students in calculus courses, particularly those studying multivariable calculus, educators teaching calculus concepts, and anyone seeking to deepen their understanding of derivative applications and limitations.
Muradean
Hi, this is a question that has been bothering me for a while. (Im in calculus II at the moment)
Why do i need to derivate some functions by definition and other times i dont? for example if somebody asks me to calculate the partial derivatives of a branch function in a a certain point, let's say (0,0).
i know how to solve the exercices but i don't understand the concept.
Thanks
In this generality, I would firstly ask, what are functions and why to consider them at all?
In the end, they are (often) used to describe a process, either in time or the dependencies between different locations. Or simply the size of a physical property. Many functions are quite complicated and one would like to have an approximation which is easier to compute. But almost always it is about to find out the behavior, i.e. the amount of changes: is it defined, is it polynomial, exponential or constant? For both the derivative can be helpful, because it is a local linear approximation and therewith easy to compute, and it shows the amount of change in a certain direction. You might want to know something about the time, a pandemic spreads, or about the slope of your track you're going to ski downhill.
hum... that seems kind of vague, i just wanted to know why in some cases i cannot calculate the partial derivates by the the rules and i need to use the definition: let me ilustrate with an example... (Lets say i want to calculate the partial derivatives of f(x,y) and f(x,y) is:
| (y³) / (x⁴ + y²) if( x,y) is not 0
| 0 if (x,y) is 0
Well, it is always the usage of the definition. The rules are proven from the definition and provide a toolbox, which might apply to a problem or not.
Asking why a certain wrench fits and others don't is a bit strange, isn't it?
Rules are way faster than the definition,(if i want to be more efficient into solving the exercices i need to use them) but sometimes, as the case i posted i cannot use them. I just wanted to know why, I am not always going to use the same wrench (definition) cause in the end i would lose time.
Sometimes the definition helps for special cases. For example, how would you prove that the derivative of ##f: x \mapsto |x|## does not exist in ## x = 0## using your rules?
ok i think I am starting to get it.
Using the definition of the derivative is more like making a wrench each time you need to tighten a nut and bolt, and the various rules are like wrenches that have already been made.
@Muradean, the word "derivate" is a word, but not one that is used in mathematics. To find the derivative of a function, you differentiate it. You don't "derivate" it.
| 0 if (x,y) is 0
For any ##(x,y) \neq (0,0)## the function "behaves well", and so rules apply readily. Of course, the rules are derived from the definition, but are easier and faster to use than the definition itself.
However, at certain points the "rules" can become problematic; expect trouble whenever you try to divide by 0, or whenever you reach the boundary of the domain of a root-function for a root < 1; for example, trouble can occur at ##x = 0## if your function contains ##\sqrt{x}## or ##x^{3/4}##, or ##x^p## for positive ##p < 1##. In your example ##f(x,y)##, we can expect trouble when ##x = y = 0##, because we would then be dividing by 0 if we tried to use the formula in line 1. Of course, when ##(x,y) = (0,0)## we use line 2, giving ##f(0,0) = 1##, so in the actual ##f## we are not dividing by 0 because we switch to a different formula.
At a "troublesome" point, you need to fall back on the actual definition of the partial derivatives. By definition:
$$f_x(0,0) = \lim_{h \to 0} \frac{f(h,0) - f(0,0)}{h} = \lim_{h \to 0} \frac{0-0}{h} = 0,$$
and
$$f_y(0,0) = \lim_{h \to 0} \frac{f(0,h) - f(0,0)}{h} = \lim_{h \to 0}\frac{(h^3/h^2) - 0}{h} = \lim_{h \to 0} 1 = 1$$
  • · Replies 42 ·
