Theoretical Lattice Energy for MgF2
11 replies · 12K views
pollycampos
Calculate the theoretical lattice energy for MgF2 (Born-Landé equation)
Ionic radius Mg+2 (coordination number 6) = 86 pm
Ionic radius F- (coordination number 3) = 116 pm
Madelung constant = 2.408
n = 7
I'm having problems with this equation, because its result is very different from the experimental lattice enthalpy of MgF2 (-2962 kJ/mol), and it must be similar.
http://img411.imageshack.us/img411/4670/quiqui.jpg
What's wrong? Maybe the sum of ionic radius? (I added the Mg ionic radius plus 2 times F radius).
Hi pollycampos! :smile:
Why add twice the fluorine radius? You need the nearest distance to the neighboring ion. What would you get, then?
So I added 86 + 116 = 202, and the result is:
http://img546.imageshack.us/img546/1336/quinooo.jpg
It's still kind of far away from the experimental result (-2962 kJ/mol), no? Or is this result right?
Thank you in advance, Infinitum :biggrin:
Based on the given information, this answer looks correct. There might be errors in measuring the values that were given, and hence the discrepancy.
Thank you a lot, Infinitum :smile: The radius information was given by my teacher's book, so I guess it isn't wrong...:rolleyes: I thought the results should be very close, because MgF2 is a very ionic solid, no?
http://en.wikipedia.org/wiki/Born–Landé_equation#Calculated_lattice_energies
The equation gives approximately equal values to the actual lattice energies. Usually less. This is because the ionic crystals, however 'ionic' you might think of them, do have a degree of covalency. You can never have a perfectly ionic solid.
Edit : In MgF2, Mg has a +2 charge, which by Fajan's rules creates a greater degree of covalency. It also is quite small, even smaller than sodium so that leads to a greater deviation from ionic behavior.
Oh yes, I think I should write that in my homework :-p Is there another reason for the experimental value be different from the theoretical? I have to write 2 reasons.
Ruh-roh! I wouldn't have explained it that way if I knew you had to write reasons :-p
Please note it is much easier to use LaTeX built into forums for such equations than to input them as images.
[tex]E=-\frac{N_A M z^+ z^- e^2}{4 \pi \epsilon_0 r_0}(1-\frac 1 n)[/tex]
Thank you, I didn't know how to use the LaTeX :-p
