songoku
- 2,512
- 394
1. The diagram shows a simple circuit.
Which statement is correct?
a. When switch S is closed, the potential difference across the battery falls because work is done against the internal resistance of the battery
b. When switch S is closed, the potential difference across the battery falls because work is done against the resistance R.
2. A cell of e.m.f E and internal resistance r is connected in series with a switch S and an external resistor R.
The p.d. between P and Q is V. When S is closed,
a. V decreases because there is a p.d. across R
b. V decreases because there is a p.d. across r
1. I answered a and wrong. The answer should be b
2. I answered b and wrong. The answer should be a
I think the potential difference across the battery will fall because there is internal resistance. Lest say if we measure the e.m.f to be 10 V, then the potential difference of the battery when the switch is closed will still 10 V if there is no internal resistance. If there is internal resistance, the potential difference measured will not be 10 V, maybe 9 V; the other 1 V goes to internal resistance. Am I wrong?
Thanks
