Thermal expansion of a glass rod and a metal ruler
The discussion revolves around the thermal expansion of a glass rod and a metal ruler, specifically addressing how temperature affects the measurements of the rod when using a ruler calibrated at a different temperature. Participants are exploring the implications of thermal expansion coefficients for both materials involved.
  • Participants express confusion about how to account for the thermal expansion of both the glass rod and the metal ruler at different temperatures. There are inquiries regarding the formulation of equations related to thermal expansion and the implications of using a ruler calibrated at a different temperature.
Some participants are attempting to clarify the relationship between the temperature changes and the measurements, while others are questioning the assumptions made about the calibration of the ruler and its effect on the measurements of the glass rod. Guidance has been offered regarding starting with the first question and considering the thermal expansion of the ruler to determine the true length of the glass rod.
There is an emphasis on the requirement for participants to demonstrate their understanding and effort before seeking direct answers, in line with forum rules. The discussion includes repeated requests for clarification on the underlying concepts and equations related to thermal expansion.
Brightly
A glass rod when measured using a metal scale at 30°C appears to be of length 100 cm. It is known that the scale was calibrated at 0°C, Find true length of the glass rod at (a) 30°C (b) 0°C [Given, coefficient of linear expansion of glass = 8 * 10 ^ (-6) degree C ^ - 1 . coefficient of linear expansion of steel = 26 * 10 ^ (-6) degree C ^ - 1 ]
L' = L(1+alpha*del(t))
I can't understand how both the material and the scale's expansion are being taken into account at the respective temperatures. Please explain the concept in detail.
Brightly said:
Homework Statement: A glass rod when measured using a metal scale at 30°C appears to be of length 100 cm. It is known that the scale was calibrated at 0°C, Find true length of the glass rod at (a) 30°C (b) 0°C [Given, coefficient of linear expansion of glass = 8 * 10 ^ (-6) degree C ^ - 1 . coefficient of linear expansion of steel = 26 * 10 ^ (-6) degree C ^ - 1 ]
Relevant Equations: L' = L(1+alpha*del(t))
What they are saying that on the scale a centimeter isn't quite a centimeter at 30 C.
@Brightly, you seem to have the mistaken impression that this is a Q&A forum where you just ask the forum to spoon feed you a solution to your problem. It is not.
We are here to help you understand how to solve problems for yourself but it is a requirement that you show some effort on your own first.
Read the forum rules.
I understand your point...but my problem with the question I can't seem to understand the approach to the question, if you can help me that will be very helpful for me.
Materials change size/shape as temperature changes. You are given the rate at which that change occurs for each of the materials, and you know the temperature that needs to be applied. What is it you don't understand?
I can't understand how to frame the equation for the first statement because I don't quite understand the meaning and also how the equations are being formed as the statements are so interlinked
Start with the first question, and then go from there. For the first question the ruler measures the glass rod at 30C, but the ruler is calibrated ("correct") at 0C. Given the coefficient of thermal expansion ##\alpha## for steel, how much has the ruler lengthened/expanded at 30C compared to 0C? So that will tell you the length of the glass rod at 30C, right?
Do you see how your Relevant Equation works? It tells you by what fraction the length increases for an increase caused by some temperature difference.
Thank you so much, You cleared all of my doubts. 😊 I worked out accordingly and my answer has matched.
