Understanding Thermodynamic Functions: H, G, and A in Simple Terms
Thermodynamic functions like enthalpy (H), Gibbs free energy (G), and Helmholtz free energy (A) serve crucial roles in simplifying calculations and understanding real processes by accounting for environmental effects. Enthalpy helps quantify the energy required for processes, considering both internal energy changes and work done against the environment. Gibbs free energy indicates the spontaneity of reactions, revealing the direction a reaction will favor under specific conditions. Helmholtz free energy is particularly useful for constant volume systems, while Gibbs free energy is preferred for constant pressure and open flow scenarios. These functions provide essential insights into phase behavior and chemical equilibria in thermodynamic systems.
manimaran1605
What are the purposes of defining the Thermodynamic functions such as H (enthalpy), G (Gibbs function), A (Helmholtz function) in Thermodynamics. I just know the expressions for this functions but unable to understand the physical significance of these functions and also haven't understand what these functions tells about thermodynamic systems (please don't explain with rigorous mathematics) try to explain it as intuitive as possible.
Science news on Phys.org
They allow to simplify calculations/measurements related to real processes, as they take into account the effect of the environment.
Take for instance enthalpy, ##H \equiv U + PV## or its change at constant pressure ##\Delta H = \Delta U + P \Delta V##. Imagine you have a process that will lead to an increase in the internal energy (##\Delta U > 0##) and expands (say a gas phase reaction where two molecules of reactant give 3 molecules of products). ##\Delta H## tells you the energy needed for the process by considering not only the increase in internal energy but also the work that has to be done against the environment.
Likewise, for instance, the Gibss free energy takes into account both the exchange of volume and of heat with the environment. For a chemical reaction ##A \rightleftharpoons B##, in an open container, the values of ##\Delta G## tell you immediately which way the reaction will go by itself. Simply knowing the internal energy ##U## is not sufficient.
Another example: why is water liquid at 99°C, and not a gas? Surely the gas has more entropy than a liquid, and therefore should be favored? Check the Gibbs free energy: it is lower for liquid water at 99°C than steam at the same temperature.
Likes 1 person
To expand further on what Dr. Claude said, H, A, and G are often very convenient to use in process calculations. H is useful in quantifying the heat effects in continuous open flow processes. A and G are very convenient to use in quantifying interphase equilibrium and chemical reaction equilibrium of systems. A is useful for constant volume systems, and G is useful for constant pressure and open flow systems.
Chet
Likes 1 person
