How Does Gas Behavior Differ in Fixed-Volume vs. Piston Containers When Heated?
The discussion centers on the behavior of gas in fixed-volume versus piston containers when heated. When equal heat is added to both containers, the fixed-volume container's temperature increases, while the piston container's gas does work, resulting in a temperature increase that is less than that of the fixed-volume container. This phenomenon is explained by the First Law of Thermodynamics, represented by the equation ΔU = Q - W, where energy lost as work (W) affects the internal energy (U) and temperature of the gas in the piston container.
  • Understanding of the First Law of Thermodynamics
  • Knowledge of ideal gas behavior
  • Familiarity with concepts of work and energy transfer
  • Basic grasp of thermodynamic systems (fixed-volume and piston systems)
  • Study the implications of the First Law of Thermodynamics in various thermodynamic processes
  • Explore the relationship between pressure, volume, and temperature in ideal gases using the Ideal Gas Law
  • Investigate real-world applications of piston systems in engines and compressors
  • Learn about the concept of adiabatic processes and their effects on gas temperature
Students of thermodynamics, mechanical engineers, physicists, and anyone interested in understanding gas behavior in different thermodynamic systems.
uestions
There is a container of a fixed volume filled with gas. There is a second container with a piston filled with gas. The containers are filled with the same amount of gas, have the same pressure, have the same volume (the piston is placed so the gases of each container occupy the same volume), and are at the same temperature.
I add equal amounts of heat to each container. The fixed-volume container increases in temperature; the piston of the second container is pushed out and the gas also increases in temperature.
Since the gas in the piston-container does work, does that mean its temperature is less than that of the constant-volume container? I would assume so because the added heat is transferred away as work.
Also, how does the relationship between V and T take into account the energy lost, and therefore decrease in temperature, when an expanding gas does work?
Chemistry news on Phys.org
Yes.
The relationship between V and T doesn't focus on the energy lost. The energy lost is accounted for by the First Law of Thermodynamics, which is essentially an energy balance:
ΔU = Q - W
where Q is the amount of heat absorbed from the surroundings, W is the amount of work done on the surroundings, and U is the internal energy of the gas. For an ideal gas, the internal energy is a monotonically increasing function of temperature.
Chet
Can a gas expand and lose temperature (because it did work on a piston while expanding)?
Yes.
  • · Replies 17 ·
  • · Replies 35 ·
