Thermodynamics - engines question
The discussion revolves around a thermodynamics problem related to engine cycles, specifically focusing on temperature and volume relationships within the context of an ideal gas. Participants are exploring how to derive certain temperatures and efficiencies based on given parameters and equations.
  • Participants are attempting to relate temperatures T4 and T2 to T3 and T1, respectively, and are questioning the use of compression ratios in the problem. There are discussions about expressing T2 and T4 in terms of other variables using the ideal gas law and specific relationships between volumes.
The conversation is ongoing, with participants providing guidance on how to express certain variables and questioning assumptions about volume relationships. Some participants are expressing frustration over incorrect results and are seeking clarification on the relationships between different volumes.
There is a noted lack of information regarding the compression ratios, and some participants are struggling with the definitions of specific heat capacities. The original poster mentions that this question is for practice and not part of formal homework.
Jaydude
I'm stuck on a question, part d below:
My attempt:
I reckon that T4 = T3 and T2 = T1, otherwise I don't know how else you can get T4 and T2...?
Once I got first part of d, I reckon I could do efficiency using part c that I derived.
I don't see where I'm supposed to use compression ratios in this question, if someone can direct me to the right path please!
(If this is supposed to be in advanced physics section, please let me know for next time!)
Kind regards,
Jay
Hello Jay. Welcome to PF!
You are given that ##P_2V_2^\gamma = P_1V_1^\gamma##. See if you can use that along with the ideal gas law to express T2 in terms of T1, V1 and V2.
Sweet! But now I'm not sure how to get t4? And how do I apply that to get work done?
I could use my equation (correct) in part b but I don't know what Cp and Cv are, how do I apply the constant 1.4 there?
(I'm going to assume t2 is correct here...)
Thanks!
Try a similar calculation to find T4 in terms of T3.
TSny said:
Hello Jay. Welcome to PF!You are given that ##P_2V_2^\gamma = P_1V_1^\gamma##. See if you can use that along with the ideal gas law to express T2 in terms of T1, V1 and V2.
But I don't have V3/V4 compression ratio :(
How is V4 related to V1? How is V3 related to V2?
I see what you did there, but I get the incorrect answer, T4 should be 1379k
What have I done wrong ?
How do you justify taking V4 / V3 to be 16?
If V4 = V1 and V3 = V2, and we know V1/V2 = 16, then V4/V3 = 16 too...?
I see my problem.
V2 does not equal V3!
Can't solve this, its getting annoying as I've spent hours ripping my hair out on this!
Bump. Can Someone point me in the right direction here/helpout with the solution? This is only for my practise and is not part of any H/W or Cwk and all of my friends are struggling with this Q too.
Kind regards,
Jay
V2 does not equal V3, but you can express V3 in terms of V2 using the ideal gas law.
  • · Replies 16 ·
