Thermodynamics: heat needed to melt block of a metal
The discussion revolves around calculating the heat required to melt an 8 kg block of metal at its melting point, using given values for latent heat of fusion, latent heat of vaporization, and specific heat. The problem is situated within the context of thermodynamics.
  • Exploratory, Assumption checking
  • Participants are attempting to apply the formula for heat needed, questioning the correctness of their calculations and the provided answer options. There is a focus on understanding the units of measurement for energy in the context of the problem.
The discussion is ongoing, with participants expressing confusion over the answer choices and the correctness of their calculations. Some are questioning the units of energy used in the problem, indicating a lack of consensus on the interpretation of the question and the answers provided.
Participants are working with specific answer choices and are uncertain about the correctness of the provided options. There is mention of potential discrepancies in the question statement or marking criteria.
teggenspiller
the latent heat of fusion for this metal is 500Cal/kg. The latent heat of vaporization is 600Cal/kg and specific heat of the liquid metal is 500C/kg K. How much heat is needed to melt an 8kg block of this metal when its temperature is exactly at the melting point?
T= kelvins
c=specific heat
Q is heat needed
Q= m*c*delta T
Q=m*Latent heat (either fusion or vapor)
Q= 8 * 500Cal/kg
Will someone please sho wme how to do this>?
What makes you think your answer is wrong?
The answer was 1600..?
thats the problem. my coices are 400, 100, 200, 1600 and none of the above. and i answered none the above, but answer is 1600.
But the answer is clearly NOT 1600. So apparently the marker (or marking program) or the question statement is wrong.
What units are the answers given in? The only thing i can think of is that the answers are given in some unit besides Calories? Either that, or the answers are wrong.
what are the units of energy, cal or cal/kg ?
ahg i see.
  • · Replies 17 ·
