Thermodynamics Homework: Find Work Given Heat & Temp Change
  • Thread starter Thread starter Robershky
    Thermodynamics
5 replies · 3K views
Robershky
When 1380 J of heat are added to one mole of an ideal monatomic gas, its temperature increases from 272 K to 275 K. Find the work done by the gas during this process.
I assume [tex]\Delta[/tex]U = Q - W is the formula to use. But for some reason I'm just confused.
I tried using 1380 = 275 - W, and got -1105. But that is not the correct answer.
That's the problem, I don't understand how they relate. Is there a conversion from Kelvin to Joules? Or do I just use 3K = 1380J - W?
Internal energy increases with increasing temperature, but the exact relation will depend on the type of gas. You should figure out how many degrees of freedom are present in a monatomic gas, then use equipartition of energy to express the internal energy as a function of temperature.
You are given Q and you can determine [itex]\Delta U = nC_v\Delta T[/itex]. So it is just a matter of applying the first law to determine W.
AM
